rattaling sound coming from front of car
Old 10-11-2010, 11:46 PM
Atticus8866's Avatar
Car Info: OH SIXer WRX (RIP)
I have an 06 wrx and i get a rattaling sound from what sounds like the front of my car when i get my car up to exactly 4250 RPMS in each gear. It doesnt happen everytime, sometimes it will do it in each gear and sometimes it wont do it at all. It used to do it periodically when the a/c was just on but now it does it with or without the a/c on. Any ideas what this could be?
Atticus8866 is offline
Old 10-12-2010, 12:05 AM
STINGR3's Avatar
Car Info: sti
Check the heat shield on your up pipe maybe the welds broke off.
Ron
STINGR3 is offline
Old 10-12-2010, 02:23 PM
trubluevoeater's Avatar
Car Info: 2005 suby sti
^^^^^agree
nemisis heat shields
trubluevoeater is offline
Old 10-12-2010, 02:24 PM
hloh's Avatar
Car Info: 05 psm WRX
definitely check the heat shields. I've had this problem before
hloh is offline
Old 10-12-2010, 04:18 PM
I checked it and it seems to be on their pretty good. no movement....
Old 10-12-2010, 05:36 PM
STINGR3's Avatar
Car Info: sti
Well it's hard to diagnose a car without actually hearing it in person but here are just some basic things to look for when the engine is cold as food for thought.... check pitch mount or dog bone on back of tmic, heat shield on the turbo (check for broken bolts and etc. causing things to rattle or metal to metal contact), down pipe, intake (if stock make sure everything is bolted on and if aftermarket cai then check around fender hole areas and etc.) Check your bumper, your hood scoop, suspension, and etc. The list can go on and on. The basic idea is to try to replicate that rattling noise by gently pushing/pulling/hammer hand action on things around the engine bay and see if you can source out the problem. Then you can rule things out and go elsewhere. Good luck!
Regards,
Ron
STINGR3 is offline
Old 10-19-2010, 01:16 PM
Nobody likes the tuna here
Heedz's Avatar
Location: Somewhere San Mateo County, Inside A 911 Ambulance
sounds like what my car does at 3500. does it sound like metal grinding on metal almost, where youthink its the wastegate or the turbine?
Heedz is offline
Old 10-20-2010, 12:17 AM
it sounds like clinkingish or rattling and it does it at the same exact rpms everytime or not at all. its weird. does yours do it at same rpms? did you find out what was wrong with it?
Old 10-21-2010, 03:59 PM
STINGR3's Avatar
Car Info: sti
^ It could also be detonation, you will have to log your car to verify this.
Ron
STINGR3 is offline
Old 10-25-2010, 11:25 AM
blackOnblack's Avatar
Car Info: 04 FXT
Mine does that too... but around 2200-2500 rpm and mostly when cold. I had the shop search around last time it was in there and they said it was the heatshield on the down pipe. If i wasn't about to get a new DP, i'd be hunting/solving the problem right now.
...but it can wait.
blackOnblack is offline
Old 11-30-2010, 09:29 PM
Car Info: 04 FXT
It was indeed the heatshield on the down pipe. Bent it back a bit and it's gone...
... although, i only noticed it when spending time inside the engine bay during the radiator swap... and now she has a blown hg omg fml.
ya, rattles suck.
Old 12-01-2010, 04:10 PM
iClub Silver Vendor
EQ Tuning's Avatar
Car Info: A Laptop
It sounds like a heatshield rattle like everyone described, but it could also be a blown out downpipe gasket. I blew mine out once and it sounded just like a turbo going bad.
-- Ed
EQ Tuning is offline
Old 03-28-2011, 09:46 AM
Suby Kid's Avatar
Car Info: 2007 Wrx Sti
had that problem with my old rs just cut the dam shields off lol
Suby Kid is offline
Old 06-05-2011, 06:17 PM
sumgai's Avatar
Car Info: 04 STi
I seem to have this sound going on now. It stops when I put the clutch in and returns at any engine speed over 2500rpms. It's like a ticking sound. Wheel speed makes no difference, just engine speed. I figured it had to be something next to, in, or around the turbo. It sounds like it's coming from right in front of the glove box. This Weds I will dig around and try to isolate it, but after reading this thread I'll check the heat shield first. Thanks peeps.
sumgai is offline
Old 06-05-2011, 06:40 PM
iDriveMyi's Avatar
Car Info: 2010 Impreza 2.5i Premium Boosted
I had a rattling coming from the back of my car at certain RPMs.. and I couldnt figure out what it was for the longest time and then finally I found out that one of the clips from my rear mudflaps was hitting the exhaust hanger everytime I got to certain RPM because of the exhaust shaking. Try to have someone replicate the vibration while you listen from the outside.
iDriveMyi is offline
gotrice?
04-02-2010 03:57 PM
Angelus897
12-06-2007 03:13 PM
STI35
10-23-2006 11:32 PM
huck
08-25-2003 04:16 PM
Quick Reply: rattaling sound coming from front of car
Top
