Max performance tires for summer (Compound R)
Car Info: 03 WRX Sedan MBP/17X7.5 SSR Comps/225 Kumho MX
I'd go with SO3s if your budget will allow it, otherwise choose the Kuhmo Ecsta MXs. For the road, I'm running the MXs at 36 PSI rear and 40 PSI fronts on a WRX, and getting even wear. You can't find better grip for the buck than the MXs.
Originally Posted by Group B
I've seen the Kumho MX's develop cracks in the sidewalls, scary stuff...
Details mean a lot. Are you sure the Kumhos you saw were MXs and not one of their other models? What sort of usage was the tire subjected to? Was it run underinflated/overinflated or drifted? Go drifting on any near R compound tire and I expect it will do worse than develop cracks. How old was it and how many miles had it been run?
I am running on the Poilot Sport Cups on my WRX and they work really well, they do need to heat up,, but once they do they become your best friend,, R compound + AWD,, is a good combo,, I am running the tires on the street and so far they have been good. They really stick to the road n little rocks that people behind you get to know very well.
Car Info: STI and Outback Sport
The problem with running street tire on the track is the heat you can generate and the tires get gooey!!
I've run the 070, MX, and PS2 and have only gotten 6,000 miles with 2 track days from each. I think? the heat may increase the wear afterwards, ie the tires look fine after the 1st track day but quite worn before the second.
My next tire will be an R compound, probably the Toyo RA-1 unless I find a better street/track R tire.
If I still can't get more than 6000 miles it will be chaeper to buy a set of dedicated rims.
John
John
zion168
May 6, 2008 02:45 PM
zion168
SoCal Classifieds
May 6, 2008 01:28 PM
munky69
May 23, 2006 11:23 AM
