What will decrease my braking distance?
Old Feb 7, 2004 | 04:14 PM
rustokman's Avatar
Car Info: Black 03 WRX
Ban SUV is right. Breaks work buy dissipating heat that is converted from kinetic energy, so getting bigger rotors and such will only dissipate heat more efficiently but it won't help stopping distances all that much. Wider and stickier tires are the key ingredient.
Old Feb 16, 2004 | 12:15 PM
KGB's Avatar
KGB
Car Info: 2000 Impreza 2.5RS BRP
Uh.... bigger rotors usually push your calipers further out, which increases brake torque - and how can that not be a factor in shorter braking distance?
Old Feb 16, 2004 | 08:32 PM
Whether you can lock the wheels up with 99% of available clamping force or 20% of it, you still can't exceed the coefficient of friction your tires can generate. If your existing brakes can lock up your tires (which they can) than adding more "braking force" can't physically slow the car down any faster. What it CAN do is dramatically improve resistance to fade, provide better brake pedal feel, and enable one to better modulate pedal pressure. Now, as was stated above, if you improve both the available grip of your tires and the torque capacity of your brakes, and you don't screw with bias, then yes, braking distance comes down.
Old Feb 20, 2004 | 03:39 PM
GarySheehan's Avatar
Car Info: 2005 Subaru STI
Stoptech's kit moves brake bias rearward by using smaller front piston sizes. So, even though you've increased the effective torque arm on the front, you've reduced the clamping force. The result is slightly less front braking force, providing a better balanced system that decreases stopping distance as well as dramatically increasing the thermal capacity of the front brakes.
Throwing a big brake kit on your WRX with a bigger rotor and with equal or greater clamping force than stock will INCREASE stopping distance because the car will have too much front brake bias and the fronts will lock long before the rears.
The only way to minimize braking distance is to balance the brake bias to the point that all four tires lock simultaneously and to be able to modulate the brakes to a point consistently just before lockup. This applies to any tire compound.
Gary
Sheehan Motor Racing
www.teamSMR.com
Old Feb 21, 2004 | 10:25 AM
Flash N Dash's Avatar
Car Info: WR Blue WRX
Hey Stoptech is developing their Kit for the rear and should help to balance out the distribution of braking force! It is due out in about 2 more months. Something to look forward to....
Brian
Flash N Dash Performance
Old Feb 21, 2004 | 11:03 AM
Uncle Scotty's Avatar
The 'H6' mod on the rears is more than adequate to increase rear brake bias, in my experience. And very cheap if you find the brackets and rotors in the boneyard.
IMO, you would be very hard pressed to find a cheaper, more effective, and easier to accomplish mod.
Old Feb 21, 2004 | 11:44 AM
scoobsport98's Avatar
Car Info: 98 Impreza Outback Sport
While reading this thread, I thought of a question of my own: I've been in the market for a brake upgrade for a while now, and I now realize that your efforts can defeat your purpose of reducing your stopping distance. I have a 98 OBS (w/ rear drums ) and I was wondering if I would be putting too much bias on the front if I were to upgrade to, say, slotted/dimpled rotors/stainless lines/performance pads? I know its already biased toward the front, so would I be better off trying to pull a drum-disc conversion (from a legacy or whatever I could find) on the rear before doing anything to the front?
The OBS isn't exactly "mod-friendly" The stock lift kit must be removed to put on springs (i sure would like to) and now this... Does anyone have a clue why Subaru decided to put rear drums on OBS's while other models get 4-disc?
Okay, my rant scattered with questions has come to an end... Thanks in advance for any answers or advice- AY
Old Feb 21, 2004 | 03:20 PM
I now realize I should have started a new thread... Too late now, sorry.
Anyway, someone out there has got to be able to help me out here...
Old Feb 25, 2004 | 01:04 AM
wagon christ's Avatar
I hear you. 10.1" disks front and drums rear on my MY00 LS wagon
Old Feb 27, 2004 | 01:28 AM
IIRC the '96 OBS had rear disc's....
SooKy
Aug 4, 2004 01:13 AM
OldGuySTI
Apr 2, 2004 10:53 PM
brian_christie
Mar 25, 2004 02:45 PM
OldGuySTI
Feb 9, 2004 11:46 PM
jimr
Dec 29, 2003 11:39 PM
