Transmission or Suspension Problem
Old Nov 23, 2003 | 10:31 AM
slvrsti's Avatar
Car Info: STI 2004
it could be alot of things.could be tire balance,rims ,driveshaft balance or even something else.is the car stock or modified?stock wheels?what year/model is it? can you make the vib. in fourth gear at the same speed?have you rotated your wheels lately?just try'n to help.it could be a very simple fix.
Old Nov 23, 2003 | 07:24 PM
It's most likely wheel/tire related if it's speed dependent.
Old Nov 23, 2003 | 09:05 PM
robb's Avatar
Car Info: 2003 Silver WRX Sedan, 1982 Corvette Collectors Ed.
My 03 rex doesnt like 5th gear at 65. Thats less than 3k rpm if i recall (im not there often) and my car will chater if i stomp on it there.....use 4th....and see if its still there...
Just an idea from a technical retard.
Old Dec 1, 2003 | 04:12 PM
BongMan's Avatar
Car Info: '01 RS BRP
yea I'm with that monkey, Ban SUVS. It sounds like a tire/wheel balance issue. If you have another set of tires drive on those and see what happens. If the same problem occurs then I would say it's a wheel bearing or something to that effect. Hopefully it's a tire/wheel weight got knocked off.
otherwise pray that your warranty covers it, or you'll be mad.
ddavis
Mar 31, 2013 10:00 AM
MindzeyeWRX02
Jan 6, 2010 01:35 AM
DesolationSuby
Apr 22, 2007 04:25 PM
(==ImPrEzAWR==)
Feb 4, 2003 03:49 PM
