Steering problem: Creaking / grinding noise on left turns
Old Oct 30, 2006 | 07:40 PM
stg2lgcy00's Avatar
Exclamation Steering problem: Creaking / grinding noise on left turns
My car is 99RS with 02 WRX swap. It's been swapped for about a year now.
I kept the original RS steering rack in the car. However out of the blue 2 days ago I started getting a intermittent creaking / grinding noise when I'm turning left. Going straight and right turns I hear nothing.
I have not changed any front suspension stuff since the swap. At first I thought it was my front swaybar cause the drivers side mount bolt was backed out 1/2 way for some reason. I put the bolt back in nice and tight but I'm still getting a noise specifically on left turns while going forward.
All steeing rack bolts on crossmember are tight.
Tie rod ends seem fine
Rubber boots are not leaking on steering rack
No power steeiring fluid has leaked
Power steering reservoir still at normal level
Power steering pump operating normally
Any ideas what it could be? I tried to troubleshoot as much as I could myself but now I don't know what else to do. My car still feels the same turning left it just makes that noise now. Let me know if you guys have any good ideas.
Old Nov 1, 2006 | 02:44 PM
STi-owns-evo's Avatar
Car Info: '02 PSM WRX
I'm not sure if I would call it creaking/grinding, but my '02 WRX made a squeaking type noise every time I made a left turn before. It started happening after my brake pads got stuck during an auto-x.
Found out it was the dust shield on my l/f brake rubbing on the rotor, but would only happen during left turns.
Old Nov 3, 2006 | 09:21 PM
stardogchampion's Avatar
Car Info: WRX
edit
borderlessworld
Jan 2, 2013 01:14 PM
A170123W
Apr 28, 2009 01:02 PM
gotwrx
May 13, 2004 12:01 AM
daybreak
Feb 16, 2004 09:53 AM
WRXncrew
Dec 5, 2003 11:21 PM
