Squeal from wheels without applying brakes?
Old Jun 8, 2005 | 12:06 AM
it could be the metal arm on the pad hitting the rotor
did you try puting anti squeak on them ?
Old Jun 8, 2005 | 02:13 AM
Ultimates don't normally squeak too bad. Try removing them, cleaning everything, and beveling the edges of the pads at a 45 degree angle. I've heard this can help dramatically for sqeaky pad compounds. The leading and trailing edges in particular- some pads come shaped that way to begin with.
Old Jun 9, 2005 | 10:37 PM
mule2k's Avatar
I had a high-pitched squeal coming from my right rear for a couple weeks. When I had it looked at it turned out that the rear axles were dry and needed to be lubed. I was happy it wasn't a wheel bearing.
HectorWRX
Apr 9, 2014 11:18 AM
hYpE-R-29
May 9, 2012 10:36 AM
mmboost
Nov 8, 2004 08:03 PM
suby_dude
Vendor Group Buys/Specials
Aug 23, 2004 12:59 PM
MashiMOMO
Sep 3, 2003 12:53 PM
