rotor advice
Old Jul 20, 2004 | 06:49 PM
silvrwrx's Avatar
Car Info: 12' Forester
rotor advice
i want to buy new rotors my stock ones on my 02 wrx are done with. but i have no idea of which ones to buy. so if you can give me some advice id appreciate it thx.
Old Jul 20, 2004 | 07:05 PM
ldivinag's Avatar
03.23.67 - 06.14.13
as soon as the rotors on my STi give out... cross drilled brembos are going in there...
it's scary when i hit the brakes when it's raining or wet roads...
Old Jul 20, 2004 | 07:14 PM
mexicanpizza's Avatar
Car Info: MMVI AW WRX STI
How would crossdrilling help that?
Old Jul 20, 2004 | 07:16 PM
blue blurr's Avatar
get some stop tech rotors. just contact MPJ and see what they have. dont get drilled tho if u plan on doing any track days. just get slotted
Old Jul 20, 2004 | 07:29 PM
Daredevil's Avatar
stick to slotted
do not buy drilled
stop tech's are awesome
hit up www.subydude.com
Old Jul 20, 2004 | 08:42 PM
yayitzian's Avatar
Hurray, it's Ian!!
Car Info: 2002 MBP WRX Sedan
what about drilled and slotted? or will they crack just the same?
Old Jul 20, 2004 | 09:09 PM
ldivinag's Avatar
03.23.67 - 06.14.13
my theory is that the water gets trapped between the pad and rotor surface and it feels like i'm stepping on the brakes and no braking action is happening.
i let off and step back on (like the water's been wiped away) and it feels normal...
Old Jul 20, 2004 | 09:13 PM
ldivinag's Avatar
03.23.67 - 06.14.13
Originally Posted by Daredevil
stick to slotted
do not buy drilled
i've had cross drilled rotors on my toyota truck for about 5-6 years now and i dont see any cracks on them.
granted i dont "track" them... but i believe the cracking is due to the holes MADE after the rotor is made, instead of casting holes DURING the making of the rotor...
Old Jul 20, 2004 | 09:14 PM
Weird, I wonder if it's the pad material being cold. The wrx doesn't to that at all. Sounds crappy to feel in the rain.
Old Jul 20, 2004 | 10:53 PM
ldivinag's Avatar
03.23.67 - 06.14.13
could be...
i remembered not having that issue when i had a wrx...
saqwarrior
Dec 11, 2008 10:56 AM
subie OCD
18
Nov 22, 2005 02:52 PM
Slack
Apr 18, 2005 04:29 PM
SubySal
Dec 3, 2003 08:22 PM
ish
15
Aug 18, 2003 07:07 AM
