opinions on brake upgrade?
Old Mar 7, 2005 | 09:07 PM
ac64drew's Avatar
first...how wide are your rims are(17x?) ..then what's your reason(daily or track) and budget($2,000 or lower)..then you can figure what to get....................
Old Mar 8, 2005 | 10:35 AM
spelk3's Avatar
Car Info: sold 2012 wrx sedan (sold 02 WRX wagon)
I've got Subaru 4pot front calipers and the "H4" rear rotors on my '02 WRX wagon. The brake feel is MUCH better than stock. The ABS also seems to work better, less likely to activate in normal driving. I have much more confidence in my brakes now.
Old Mar 8, 2005 | 06:54 PM
Originally Posted by trouphaz
they are 17x7.5 with Pirelli PZero Nero M&S tires.
Put decent tires on and you'll be surprised at how much your braking improves. I would try the Stoptech Stage 2 kit before going to big brakes. There's a marked improvement. Just make sure you get true track pads before any track days.
Old Mar 8, 2005 | 07:54 PM
jdepould's Avatar
Car Info: 1990 thing
Neros are decent tires . . .
Old Mar 8, 2005 | 10:05 PM
Maybe my standards are a bit high, but I don't think anything with an M&S rating is "decent."
Old Mar 9, 2005 | 05:12 AM
jdepould's Avatar
You'd be surprised. Granted they aren't S-03's or anything like that. That having been said, if you live in an area where you see snow, but don't want to run a dedicated snow setup, Nero's are a good choice, actually I run all seasons in the summer and snows in the winter, but that's because I can't find summer tires in my size. But my all seasons are Falken ZE-512's which were noticeably better than the standard michelin all seasons that were on the car when I bought it.
Old Mar 9, 2005 | 03:30 PM
fastnoypi's Avatar
whats a stoptech stage 2 upgrade?..never heard of it
I have the stoptech BBK and oem replacement stoptech rotors on the rear and it stops on a dime. The stock brake proportioning is right on. Highly reccomended as an upgrade from the stock wrx brake setup. The only thing im planning to do to make the experience better is to upgrade my rear OEM lines to stainless braided replacements.
Old Mar 9, 2005 | 03:43 PM
Pads, rotors, lines, and fluid from Stoptech. Stage 1 is the same without rotors.
SubySal
Dec 3, 2003 08:22 PM
1Slow///M3
Sep 5, 2003 07:28 AM
Steve Tack
May 10, 2003 12:29 PM
aWrxer
Apr 23, 2003 10:37 PM
