how to eliminate understeer in the STI (negative camber on the front??)
Old May 10, 2005 | 08:03 PM
To eliminate understeer, here's a few things you can do.
*bigger, stickier tires. More grip=less understeer
*more camber (to a point, street tires won't make use of more than -2.5 degrees or so)
*more caster (from an ALK or PSRS- improves the amount of dynamic camber as you turn in)
*more roll resistance to reduce camber loss from suspension compression
Old May 12, 2005 | 09:18 AM
javaburnz's Avatar
Thanks for the help!
anybody else have some Ideas?
I know some of you out there have awsome setups without swapping out your entire suspension.
Old May 13, 2005 | 10:08 AM
Pietrek's Avatar
Change the rear lsd to cusco lsd 1.5 way(RS type).
Old May 13, 2005 | 03:42 PM
Dodzilla's Avatar
I thought thicker swaybars meant less body roll which in turn means the car can corner quicker? You're saying a thicker rear swaybar actually hurts cornering?
soundwave
Aug 2, 2004 08:01 PM
xom
Jul 20, 2004 10:36 AM
xom
Jul 12, 2004 06:17 PM
Danno
May 2, 2003 09:32 AM
Tommy3rd
14
Apr 25, 2003 05:15 PM
