Hard brakes
Old Dec 8, 2003 | 02:51 AM
NaVaWRX's Avatar
i also have same problem , it feels like the brake "delay". And when i hit the brake, go over bump, or slow turn, it makes a werid sound, but i'm not sure if it's from the brake or suspesion. my car is 02 WRX seden. And yes i'm new to this car, so any expert help here?
Old Dec 13, 2003 | 07:22 AM
mayrider's Avatar
Car Info: 02 Black wrx sedan
My problem sounds very similar, it feels like the anti-lock brakes are taking over with a real hard brake pedal and pulsing in the pedal. Usually happens when I’m turning (even slightly) and need too stop quickly. My wife’s grandprix has anti-lcks and you can stand on them and it stops without a slip of a tire, something wrong please help
Old Dec 13, 2003 | 03:07 PM
Wingless Wonder's Avatar
When the ABS activates on a WRX, you will know it by the pulsing pedal, a noticeable noise (ABS pulses brakes), and the sensation that the car is no longer slowing down. It is still slowing down but not at the usual rate of deceleration. The ABS is a little too sensitive on the WRX, in my opinion, and nothing can be done about it short of getting stickier replacement tires.
My ABS will activate if it sense the least amount of brake lockup or speed differential between wheels on wet surfaces, and has also activated while braking only moderately if I hit a bump or manhole cover in the road.
Replacing pads is not the solution to troublesome ABS - this will merely make the situation worse. You need more grip from the tires, as the ABS activates when it thinks there is skidding.
If under braking you do not feel pedal pulsing or hear the shuddering noise from the ABS, then your brake problem is something else.
Old Dec 14, 2003 | 06:42 AM
mayrider's Avatar
You hit my prob on the head, so I’m guessing a big brake conv. won’t help.
Do you know if any aftermarket abs up grades. Cause this sucks.
Old Dec 18, 2003 | 11:08 PM
mmboost's Avatar
Hmmm well Shado's original problem sounds like brake lines that need bleeding just from the introduction of air over time or boiling. Getting high quality break oil (DOT 5) will give you better protection over the boiling. And if you;re going to bleed why not upgrade to stainless steel lines only $90. You're breaks will feel VERY solid.
As for the others, when you break when losing traction in such a way that the ABS feels it cannot compensate for the terrain (like a bumpy road) I think the ABS guesses your airborn and lets the pedal sink. Think about it, if you brake when airborn, what's gonna happen when all your momentum touches the ground again Now, this is just an educated guess...so...
jason
Old Dec 19, 2003 | 11:02 AM
babysmurf's Avatar
Car Info: '08 GT3/'08 Cayenne Turbo/'02 WRX Sedan/'95 E36 M3
or some motul rbf 600... really good bang for the buck
Old Dec 19, 2003 | 12:00 PM
mmboost's Avatar
Originally posted by jlevy
You're kidding, right? Do you really mean 5.1?
No I wasn't kidding... I meant DOT4; it was a typo I missed. (Hence, no ".1" after it ). I was thinking the same thing babysmurf was actually... RBF600.
I drink a bottle every morning.
jason
AMS
Jul 27, 2007 09:10 AM
psoper
Meetings, Events & Donuts
28
Jul 10, 2006 11:08 PM
dunnojack
Jul 19, 2005 02:15 PM
suby_dude
Vendor Group Buys/Specials
Aug 23, 2004 12:59 PM
IS2Scooby
Sep 13, 2003 03:12 PM
