Creaking in front suspension of 01 H6 LL Bean
Old Jan 10, 2005 | 11:18 AM
meilers's Avatar
I have this problem too, but the mechanic said (over the phone, he hasn't seen the car yet) that this is a front suspension member problem, possibly a collapsed shock, and not a CV boot or bearing problem. A CV boot or wheel bearing problem is usually a "clicking" sound when you turn (or a loud screaming sound, if the actual bearing hub has thrown its grease); a creaking sound is related to the springs.
Can you feel the creak through the steering column?
Old Jan 14, 2005 | 08:46 PM
HellaDumb's Avatar
Car Info: 72 Vespa with curb feelers
My WRX was doing the exact same thing, and it turned out to be very simple. There was a bit of dirt or something in the spring seat. The mechanic cleaned it and then used compressed air... it never came back. One way you can tell if this is the problem is by spraying the upper and lower seat of the spring with the garden hose. You could also squirt some oil in there once it's dry, to prevent it from coming back.
The symptom was a slight squeeking over bumps, and when turning the steering wheel. It was most noticeable when in a parking lot going slow.
Old Jan 31, 2005 | 10:02 AM
DLC's Avatar
DLC
Car Info: 2000 Leg GT LTD
Glad to hear it was something so simple.
Old Oct 26, 2005 | 07:13 PM
kirk's Avatar
Car Info: 96 Subaru Legacy L
im havin that exact problem...replaced the front axle...cv boots...new rotors and pads...still squealin....gettin really fed up with it....somebody toldme it might be the power steering pump...any agreements?
legacysti95
Subaru OEM Parts For Sale
Feb 3, 2007 12:45 PM
gotwrx
May 13, 2004 12:01 AM
WRXncrew
Dec 5, 2003 11:21 PM
deke
Jul 4, 2003 07:57 PM
Broz
Jan 27, 2003 10:03 PM
