constant alighment problems
Old Oct 2, 2006 | 04:04 AM
chris8c8's Avatar
Car Info: none
at first i had an auto 2.5i and from the day i got it to the day i sold it my steering wheel was never strait (even after alighment). now i have a manual 2.5i and it was strait wen i got it but now im having the same problem its strait wen i come out of the alighment shop but after i drive it a little and not hitting any pot holes or ne thing 2 that affect it got thrown off again. so i got white line's rear frame bolts witch are sapose 2 keep things in line and they did for a while but my steering wheel still isnt strait.
so my general question is dose ne one else have this problem (if so why?)
what can i do?
and ne alighment specs that i should use would help alot
Note : i have a 1.3" drop in the front and a 1.0" in the back with the frame bolts and type 1 cusco frame brace
Old Oct 2, 2006 | 07:06 PM
Wingless Wonder's Avatar
When the shop checks your alignment after the steering wheel goes off-center, has it changed from the previous settings? Did you buy your car new, or was it by chance a former salvage title with accident history?
Old Oct 3, 2006 | 09:37 PM
chris8c8's Avatar
Car Info: none
its a totaly new car, i guess i could ask them 2 check thanx 4 the help
Old Oct 4, 2006 | 01:08 PM
Checkpoint's Avatar
Car Info: 00 RS
Make sure its tight where the collum enters the stearing rack. They slip easy if not tight. That would explain why you keep taking to the shop and it keeps ****ing up.
subaruferrucci
Mar 3, 2007 10:53 AM
chris8c8
Sep 30, 2006 01:28 PM
grex767
May 27, 2006 10:37 AM
dorifto88
Apr 22, 2003 10:24 PM
