wheel bearings? noise
Old Mar 26, 2006 | 07:26 PM
22ndavewagon's Avatar
Car Info: blue wagon
i dont know if this would the right place to thead this but the front right side is making creaking noises with every rotation of the wheel. im thinking its the wheel bearing. how would i kno for sure? any help?
Old Mar 27, 2006 | 04:42 AM
Wingless Wonder's Avatar
I've had bearing failures in other cars and it was more of a grinding sound (metal-on-metal). Does it make the sound if the car is raised and you spin the tire/wheel by hand? Have you checked your brake pads lately? Some pads are equipped with metal tabs that scrape the rotor when worn, acting as a wear indicator.
By the way, what do you drive (model, year)? If we know what model year your car is, or better yet, the vehicle mileage, someone might be able to give a better answer about what the problem might be.
Old Mar 27, 2006 | 12:24 PM
i know its not the brake indicator becuase i heard that on other cars as well. but i havnt lefted on car up yet. so i dont know if it makes that sound when its lefted.
some more info: my 2002 wrx wagon hit a curb in tahoe. so the left transverse link was bent and i changed that. so when brought in to get the alignment done the mechacnic said the right strut is bent. i told him i was going to put in the tein basics so he said to drop that in before the alignment. im getting the basics tomarrow so when i drop it in ill see if the the noise still comes up when the car is lefted.
note that the both front wheels have bad chamber like
this great illustration here ( \ \ )
i have the wrx manual in cd and it says that i have to take out the entire axel to see weither or not it the wheel bearing. is that true? kinda of have a hard time reading all the mechanics acronym. (s.f.j.)
Old Mar 27, 2006 | 01:22 PM
scoobsport98's Avatar
Car Info: 98 Impreza Outback Sport
jack the car up and see if you can wiggle the wheel.... if it wiggles, the wheel bearing is out.
but yeah... WW is correct (when isn't he? ) about the type of noise, more of a grinding.. is this what you meant? or is it really a creaking?
Old Mar 27, 2006 | 01:26 PM
doughboy's Avatar
Car Info: GDA
when my bearings failed, it produced a ticking noise when the wheels were turned. it's sort of a creaking noise.
i brought it to a bay area Suby shop but they didn't know what it was, so i went to Kevin at Auto HQ. after a 5 minute test drive, he was certain it was the bearings.
i hope that helps you somewhat.
Old Mar 27, 2006 | 07:01 PM
yea i guess it can pass for grinding. but very mildly.
thanks guys when i left up the car ill let u guys kno
Old Mar 28, 2006 | 11:28 AM
bump
Old Aug 16, 2006 | 10:33 PM
spectra's Avatar
Car Info: 2003 WRX Blue
I am going to have to have one of my wheel bearings fixed. How much is it for the bearings and how difficult is it VS. taking to a shop?
Old Aug 16, 2006 | 11:01 PM
spectra's Avatar
I search the web to find some wheel bearings for the 2003 WRX and this is what I found the "Koyo #K8000-29969" for around $50.00 this is the front bearing. Is this what all of you have used or is there a different band that is better. Also do I have to get any seals or anything else that won’t come with the bearing or is the bearing all I need to order?
Old Sep 20, 2006 | 07:41 AM
93Impreza's Avatar
Car Info: 93 Impreza - SOLD
The disassembly and reassembly isn't too tough. In fact, here is a nice step by step with pictures.
http://www.scoobymods.com/forums/showthread.php?t=6420
The only trick would be pressing the old bearings out and pressing the new ones in.
Old Oct 4, 2006 | 01:16 PM
Checkpoint's Avatar
Car Info: 00 RS
Make sure it isn't a stupid little rock between the pad and rotor. This will make some grinding noise.
Once you get the race out when changing the bearings, Weld a bead around the inside of the bushing. This will shrink the bushing and make it press out easier. Also, you'll have the bead to press against and the old bushing can be used to press in the new one with out getting stuck. Try it. Fun for kids!
skyewrx
Aug 1, 2004 12:30 PM
(805)2.5
Jan 19, 2004 07:58 AM
JB
Jul 26, 2003 05:04 AM
scoobsport98
Jun 6, 2003 03:23 PM
LeeRoy
Apr 16, 2003 10:50 AM
