Changing rotors and pads / help
Old Sep 22, 2005 | 11:42 AM
wrxed1266's Avatar
Car Info: 2005 WRX Sedan
Exclamation Changing rotors and pads / help
I have an 05 wrx sedan, i just purchased stoptech replacement rotors for the front. I was wondering if this is a straight install, i have nevered changed the brakes on a wrx before. Is there any tricks or special tools i will need to due this. I am new to this so any info would be greatly appreciated.
Old Sep 22, 2005 | 04:07 PM
SignalWRX's Avatar
Car Info: 04' WRX
rubber hammer could help with getting the rotors on and off
Old Sep 23, 2005 | 07:49 PM
highrevimpreza's Avatar
Car Info: impreza L awd 93 white
when disconnecting the brake line make sure you dont spill too much fluid because if it goes below the min level you will have air in your brake line and its going to be a ***** to remove it even if you bleed it, it will still be hard just becarefull
Old Sep 24, 2005 | 04:58 PM
lovesmysuby04's Avatar
Car Info: 06 STI WRB/Gold
The front stock rotors have two threaded holes. After removing the calipers just torque in some bolts and they should pop off. Make sure too tighten the bolts evenly and I don't remember the size you need though
pyrilium
Apr 26, 2006 08:26 PM
gruppe-s
Nov 3, 2005 05:06 PM
DougZ
Jun 12, 2004 07:14 PM
t-wrexxx
Apr 9, 2004 09:03 PM
WorldONE
Vendor Group Buys/Specials
Dec 11, 2003 10:43 AM
