Brake fluid
Old May 2, 2004 | 07:31 PM
SlickmisterN's Avatar
Car Info: 2004 Black/Gold STi
cool thanks
Old May 7, 2004 | 04:23 PM
Peaty's Avatar
There is a lot of brake info here:
http://www.scoobymods.com/forums/showthread.php?t=1122
Down the page specific info on fluid.
Old May 23, 2004 | 09:11 PM
Turboman's Avatar
Car Info: 02 Blue VH8THIS
I have a Rotora 4-pot kit and i had the damdis of to keep it pressurized every hard stop I did I would loose pedal fill till I bled theh againe an againe till I put in MOTUL 5.1 .Pedel fill is very very sharp at the slites tap my WRX STOPS and with less ABS kicking in,an we all know that the WRX's ABS aint worth crap!
Old May 25, 2004 | 09:27 AM
Egan's Avatar
Originally Posted by GottaREX
Who sells these around here. I live in the East Coast and can't seem to find them.
I bought my Motul fluid from FT at SELGP when I got my SS lines. I think he is in the DC area.
http://www.selgp.com
Old May 26, 2004 | 04:37 PM
BobbyD's Avatar
http://www.swedishbricks.net/700900F...Comparison.htm
--bobby
Old May 26, 2004 | 05:41 PM
Egan's Avatar
Good find Bobby! :banana:
Old Jun 10, 2004 | 10:03 AM
GarySheehan's Avatar
Car Info: 2005 Subaru STI
DOT 5 is more compressable than DOT 3, 4 or 5.1 fluids and will hurt your pedal feel. In addition, DOT 5 is incompatible with DOT 3, 4 or 5.1 fluids. There is absolutely no reason to be using DOT 5 in your street car.
While Ford HD fluid is indeed inexpensive and has a high boiling point, it absorbs water VERY quickly and will soon be operating at it's wet boiling point. So you will have to flush it (not bleed it) much more often.
If your car isn't on the track, the autoparts store off the shelf brand name fluids will be fine. Trackers will want something with a higher boiling point such as Motul, ATE, etc.
I've used Castrol SRF almost exclusively in our racecar. While it is expensive up front, it really does not like water and does not absorb much of it. It's wet boiling point is in the range of the other fluids dry boiling point. I don't bleed my brakes at all throughout an entire racing season. It works out cheaper for me because I waste less time on flushing the brakes and buying more brake fluid.
Gary
Sheehan Motor Racing
www.teamSMR.com
JMeltzer4
Aug 17, 2010 07:23 PM
RavSpec
Apr 15, 2006 09:13 AM
mbquarts
Nov 2, 2005 03:22 PM
StopTech
Sep 3, 2003 01:32 PM
