Brake fluid
Old Apr 7, 2004 | 02:30 PM
DaWorstPlaya's Avatar
Car Info: WRB 2003 WRX
You can use either. Dot 4 is higher performance. Just don't use Dot 5 thats all....
Old Apr 9, 2004 | 02:08 PM
DrD's Avatar
DrD
Car Info: 2012 Legacy 2.5GT-L
Originally posted by FDTT
Off topic:
When would you want to use a DOT 5 fluid. Would that be in a hard braking race inviroment? Or not at all?
Dot 5 is generally silicone based - the only people who really use it are those who have show cars (it won't damage paint like a normal brake fluid, but it's also immiscible with water, so the water tends to pool, then form steam when the brakes heat up, resulting in a very mushy pedal and decreased brake performance) - the dot 5.1 oils are not silicone based, so you can use them.
essentially, the higher the dot rating, the higher the wet and dry boiling points.
Old Apr 10, 2004 | 07:07 PM
GotBoost?'s Avatar
Car Info: 2003 PSM STi
what DOT rating fluid comes in the wrx from the factory? 3? Is it bad to mix DOT 3 with DOT 4? Would a big brake kit benefit more from DOT 4 fluid or DOT3?
-Ted
Old Apr 10, 2004 | 07:09 PM
dropkick_muppet's Avatar
Car Info: '03 PSM Sedan
Ted,
you're going to use DOT4. either ATE Super Blue or Motul RBF600 is what i'd go with. ATE has a lower boiling point, but with the stoptechs you bought, that shouldn't be much of an issue. i've got a spare can of ATE in my garage.
Old Apr 10, 2004 | 07:14 PM
GotBoost?'s Avatar
whatcha doin this evening?
Old Apr 10, 2004 | 07:16 PM
not a hell of a lot when i get done with dinner.... why, you working on your brakes?
Old Apr 18, 2004 | 01:53 AM
Mach5WRX's Avatar
Angry Dan
Car Info: 05 Evo VIII
Thumbs up
Motul RBF600
:banana:
Old May 1, 2004 | 03:14 AM
GottaREX's Avatar
Car Info: 02 WRX
Originally posted by Mach5WRX
Motul RBF600
:banana:
Who sells these around here. I live in the East Coast and can't seem to find them.
Old May 2, 2004 | 02:31 PM
SlickmisterN's Avatar
Car Info: 2004 Black/Gold STi
For the STi brakes what brake fluid would you guys recomend? And where would I go to get my brakes bled and te fluid put in? Can i just take it to the dealer?
