2002 wrx pinging sounds low speed only???
Old Apr 18, 2014 | 07:49 PM
bmxhotsauce's Avatar
Car Info: subaru
only have at 5-15 MPH then goes away.
Checked everything and nothing was loose. I did notice the inner tie rod boots were both ripped.could dirt get in there and somehow make noise ??
i do have s piece rotors but nothing was loose and double checked.
could this be an axel? please help thank you
Old Apr 19, 2014 | 01:38 PM
Car Info: subaru
BUMP!! any help? could a bad axel maybe cause this?
Old Apr 19, 2014 | 02:25 PM
shimmies's Avatar
Car Info: 03 WRX Wagon
My axle clicked like that when it was bad, replaced the axle and haven't heard the sound since. Sometimes the axle nut may also have come loose. Worth a shot to replace with a new nut.
Old Apr 19, 2014 | 02:33 PM
Car Info: subaru
Thank you. I have new axle .thank you for your help
Old Apr 23, 2014 | 08:52 PM
Car Info: subaru
Update found out this noise is coming for my ray wheels one of the2 valve stem bolts most have back off and is rolling around in my tire.
wrx10404
May 6, 2004 10:03 PM
gogo_yubari
Mar 2, 2004 01:27 AM
MauiJammer
Feb 9, 2004 10:41 PM
teamipr
Jun 10, 2003 11:49 AM
