squeeking timing belt noise???
Old Dec 5, 2004 | 08:35 PM
nic3krnnamja83's Avatar
i get sorta of squeeking noise when it is really cold and i start it up, usually after it goes away, but i used belt ease on it and it seems to make the sound go away... should i change out my timing belt or is it ok, i know super nub question but i would like to know thanks
brandon
Old Dec 6, 2004 | 12:43 AM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
It is probably your AC or PS belt, not timing belt.
Old Dec 6, 2004 | 07:41 AM
do i need to change anything?
Old Dec 6, 2004 | 09:53 AM
DetailAddict's Avatar
Former Vendor
Car Info: Evo X
like alex said, mostly drive belts... how long have you have those belts for? They are not hard to change. if you are doing it your self, it's not that expensive. I sold my two subarus in the past before I had to change the belts, so I don't know the price. But I just got some belts for my 98 protege and they were only about $30 for alternator and power steering belts.
if you don't have that many miles on them. often time is when the belt got wet or oil drip on it. good luck!
Old Dec 6, 2004 | 12:57 PM
i am just rolling aroun 48000, i thought this was a 60k thing to do? should i worry and wait or just change them out...ooo maybe water cause its really cold and it just rained
Old Dec 6, 2004 | 02:23 PM
Former Vendor
Car Info: Evo X
my belt has been squeeking for the past 20k. I just got some belt spray to temperary fix the problem until now (120k). I am not saying you don't need to replace it (don't want to get blame for it you know ), but my car has been running fine for the past 20k. good luck!
Leo
Old Dec 21, 2004 | 11:11 AM
OneFast944Turbo's Avatar
Car Info: 87 944 Turbo Porsche -
Most likely thats not the timing belt.. and honestly there is no way to check if the timing belt is making noise,but you could do this. Open the hood and pour or spray water on each pulley one at a time if the sound stops or gets louder... TAAAADAAAA!!!!!!!! you found and solved your problems. Tighten or losen the belt and it'll go away....
Old Dec 21, 2004 | 04:45 PM
Former Vendor
Car Info: Evo X
don't use water. you can get special belt spray at autozone or kragan. Often time water would make it worst.
Old Dec 21, 2004 | 05:24 PM
Yes that is the whole point to make the sound worse or to stop it for a minute. Its not supose to be a solution, its just a way to find out exactly where the noise is coming from..
wrecker83
Oct 7, 2010 11:07 PM
strider327
Mar 11, 2009 12:38 PM
mattrudella
Sep 9, 2003 09:26 AM
