squeaking sound (when using A/C)
Old Jul 12, 2005 | 12:09 PM
subiescottwrx's Avatar
Red face squeaking sound
Hi folks, got another rookie question,
when i turn on my AC there is a loud squeaking sound......it almost appears to happen when i turn with AC on .....it sounds like belts or something?
Old Jul 12, 2005 | 12:44 PM
Nick Koan's Avatar
Car Info: Legacy GT
Could be dusty belts, or old belts. Is it only when the A/C is on? Or anytime the fans are on?
Old Jul 12, 2005 | 12:48 PM
only when Ac is on and Fans i guess.....maybe just fans, not too sure yet
Old Jul 12, 2005 | 12:49 PM
like if i give it a little gas, that seems to irritate it too
Old Jul 12, 2005 | 06:56 PM
Wingless Wonder's Avatar
Most likely the belt that drives the A/C compressor. The clutch in the compressor engages when you turn the A/C on, this puts an almost instant load and drag on the belt, sometimes causing it to slip. That is likely the squealing sound that you hear. Check the tension on the belt. If you don't know how tight it's supposed to be, take it in for service. They should also be able to determine if the drive belt itself needs replacement. How many miles on the vehicle (belt)?
Old Jul 12, 2005 | 08:40 PM
sinatra's Avatar
Car Info: 04 FXT 4EAT
I have the same thing. Sounds like a bird chirping under the hood. It does it consistantly every 2 minutes or so when the A/C is running. No other noises though when A/C is off. Car has 35,000 miles. 02 WRX.
Old Jul 12, 2005 | 10:16 PM
Turbo86's Avatar
Car Info: 2003 WRX Sedan
The Exact Same Thing Is Happening To Me... I Drive An 03 Sedan
Old Jul 13, 2005 | 12:08 AM
doughboy's Avatar
Car Info: GDA
it's the AC belt. my '02 WRX does it when i turn on the AC....it's a brief chirping sound that goes away after a second or two.
have them check the belt tension on your next service maintenance.
Old Jul 17, 2005 | 01:27 AM
RshaoKh's Avatar
Car Info: Subaru WRX Impreza 2002
I had the same problem too and I took it to the dealer. They said that I needed a new AC compressor.... Luckily the warrenty covered it.
Old Aug 26, 2005 | 08:56 AM
huffyrex's Avatar
Car Info: 2003 WRX
i had the same problem with my ac. i have 48k on mine. the belt is getting lose, all i did was tighten up the tensioner wheel and the squeek went away, bodda bing, it was gone, its easy to do.
Old Aug 27, 2005 | 07:58 PM
bluewrx82's Avatar
i have a 03 sedan, same problem. i took it to the dealership and they told me it was normal!? but if i have my A/C on and im driving the car from 4.7k to 6.5k rpms, it squeels
a lot.
Old Aug 28, 2005 | 02:30 PM
MyRad25rs's Avatar
Car Info: 2000 impreza 2.5RS
I have a '00rs and I get a very "Barry White" sound compared to these read. I have 58k on mine. I rarely get this anymore, but it is when I start the a/c.
McLovinMyWRX
Nov 13, 2010 09:32 AM
7scooby
May 18, 2005 11:21 AM
MRF582
Mar 3, 2004 09:47 AM
impreza2002
Feb 6, 2003 11:35 PM
Zoeb2s
Dec 3, 2002 05:09 PM
