Trunk wont open from inside! Help!
Old Jun 3, 2003 | 07:03 PM
vapor's Avatar
I cant open the trunk using the release lever inside the car. I pulled it up all the way, but the trunk doesnt pop open, I'm scared that the lever would snap if I pulled any harder. I can still open it using the key, and I made sure it's not at the "cancel" position. What's going on?
Old Jun 3, 2003 | 11:59 PM
ish's Avatar
ish
i had a similar problem, once it was in the cancel position, another time i had to reposition the latch to be a little higher (the part connected to the car, not the trunk) and that fixed it with no problem all better
Old Jun 4, 2003 | 10:23 AM
DarriiffftaaHuy's Avatar
yeah its just one of the "problem areas" of the car. not a big deal if your "key lock" isnt on, but if it is on and your latch isnt working, then you are screwed and you have to climb into the trunk to "unlock" it and climb back out to open it.
my friend had to do that, lol... good thing she's a petit lil thing... lol
Old Jun 4, 2003 | 01:50 PM
Chris04WRX's Avatar
Car Info: 2004 WRX Sedan
I've experienced the same difficulty opening the trunk using the release lever. I played with the cancel switch and got it to work pretty well. Haven't had a problem since. I guess this is common with the '04's.
Old Jun 4, 2003 | 05:23 PM
Peaty's Avatar
I have a page on it:
http://www.scoobymods.com/forums/sho...ght=trunk+open
and a pic:
Old Jun 4, 2003 | 05:57 PM
Peaty's Avatar
All my stickers are in my trunk out of site, including all the badges I only have one on the car I put a Small AWD from the WRX in the center bottom rear of the back window.
kukoo4cocopuffs
Feb 22, 2015 07:00 PM
wrx 03i
Aug 18, 2011 06:58 PM
SR20steve
May 16, 2010 12:02 PM
GripItUp
May 22, 2009 12:13 PM
Petter Solberg
Sep 6, 2005 02:17 PM
