05 Sti problem.. Help please.
Old Apr 15, 2014 | 06:09 AM
Vladi's Avatar
In Russia, Title Choose You.
Car Info: Everywhere
We shall see tonight
Old Apr 15, 2014 | 08:06 AM
06stibeast's Avatar
Car Info: 1993.5 toyota supra, 05 AW Sti
Originally Posted by sybir
Did you check the belt? Your symptoms match a toasted belt - makes noise, doesn't turn the accessories, and random dash lights is what you see when running voltage is way low. The alt and ps pump share a belt.
ya I thought the same thing, visually the belts look fine. I believe the previous owner had them replaced. They do feel a tad bit more loose then they should, I don't think it would be that loose to cause the problems. I could be wrong though.
Originally Posted by dthack03
If not, I have a obd2 code reader you can use to diagnose. Don't know if I could be of more help than that, but PM if necessary
Thanks a bunch!
Old Apr 15, 2014 | 06:16 PM
06stibeast's Avatar
So the code it came up with is a p0030 02 sensor range and my cruise control light flashes constantly. Thanks again Vladi
Anyone else had this problem??
Old Apr 15, 2014 | 06:28 PM
Vladi's Avatar
Welcome.
My 1st guess is primary o2 is going bad. Your fuel trims are all over the place. Car is pulling and adding fuel randomly, and knocking as a result.
Next I'd check for boost leaks like we discussed.
*edit: I also thought I saw the wire kinda chewed up near the o2, that's why I kept trying to look down there.
Old Apr 15, 2014 | 06:57 PM
06stibeast's Avatar
Originally Posted by Vladi
Welcome.
Ya if I'm not neck deep in the motor swap on the supra this weekend I'll change my oil and check that sensor out and replace it if necessary. Clean my maf then take it for a boost leak test.
Old Apr 21, 2014 | 10:59 AM
06stibeast's Avatar
looks like it was my bank 1 sensor 1 a/f 02 sensor. That thing was shot, no more check engine light so far and seems to be running fine. Thanks again for the help vladi!
Old Apr 21, 2014 | 11:12 AM
Vladi's Avatar
Great. You're welcome
NoLimitSTi
Oct 11, 2008 10:20 PM
LongLiveGDB
Mar 21, 2006 09:38 PM
hiphopp
Jul 5, 2005 10:33 AM
slow04wrx
Apr 25, 2005 11:21 PM
RUDEBWOY
Jan 4, 2003 11:19 AM
