05 Sti problem.. Help please.
Old Apr 13, 2014 | 12:11 PM
06stibeast's Avatar
Car Info: 1993.5 toyota supra, 05 AW Sti
Hey I-club!
So I started my car up yesterday. When I turn the steering wheel it almost feels like the power steering is out, it's kinda hard to turn. The weirdest part though is when I turn the wheel a bunch of lights on my cluster come on. Cruise light flashes. Brake light comes on, diff light comes on and the airbag light as well.
Any clue as to what this issue could be? I don't want to drive it because I feel like it is a safety issue. Thanks for the help guys.
Old Apr 13, 2014 | 01:55 PM
Heedz's Avatar
Nobody likes the tuna here
Is your clock spring still working?
Old Apr 13, 2014 | 02:49 PM
06stibeast's Avatar
I'm not entirely sure? How would you know?
Old Apr 13, 2014 | 05:45 PM
Vladi's Avatar
In Russia, Title Choose You.
Car Info: Everywhere
the "no power steering" feeling sounds like compressor is either going out or dead, or there's air in the system.
the other issue sounds like you may have an electrical short somewhere near the clockspring or steering column.
good luck
Old Apr 13, 2014 | 06:14 PM
06stibeast's Avatar
good luck
Thanks for the info. Ya I've never had an issue like this before. I know you liv around the corner from me, If your not busy would you mind swinging by one of these nights and see it first hand? I was also thinking about taking it to Roseville Subaru or to Paul.
Old Apr 14, 2014 | 02:29 AM
dthack03's Avatar
Car Info: bugeye
Check the pump first, including the rubber o-rings for minor leaks. Then for air in the system as stated previously as I had almost exactly the same issue years ago with both of the prior issues occurring. But I only threw one idiot light, so with all those popping up it may be a deeper issue. Good luck solving the problem
Old Apr 14, 2014 | 03:54 AM
1JavaBlk_in_Sac's Avatar
Car Info: $2000 hawkeye
Do you get air bubbles in ps reservoir?
Old Apr 14, 2014 | 07:47 AM
Vladi's Avatar
Originally Posted by 06stibeast
If your not busy would you mind swinging by ...
I am extremely busy, but you're literally just down the street so I can def take a look. PM me your number or something.
Old Apr 14, 2014 | 10:44 AM
06stibeast's Avatar
ya it's so odd to me. I don't see how air could have got in the line, I've never messed with it.
It just happened randomly, I have only had the car for about a month now. Never touched the power steering. It's been fine until Saturday morning.
Old Apr 14, 2014 | 10:57 AM
per/pet/ual's Avatar
Registered Mustachio
Car Info: 2004 wrx wagon
If you need an o ring for the ps pump inlet shoot me a pm, I have like a hundred of them, I'll give ya a few
Old Apr 14, 2014 | 11:11 AM
06stibeast's Avatar
Thank you I appreciate it.
Old Apr 14, 2014 | 11:15 AM
No problem
Old Apr 14, 2014 | 07:49 PM
06stibeast's Avatar
Now check engine light popped on and the drive belts are squeaking. Vladi if you happen to have a obd2 cel code reader can you bring that as well?
Old Apr 14, 2014 | 10:22 PM
sybir's Avatar
Warm Fuzzy Admin
Did you check the belt? Your symptoms match a toasted belt - makes noise, doesn't turn the accessories, and random dash lights is what you see when running voltage is way low. The alt and ps pump share a belt.
Old Apr 15, 2014 | 03:07 AM
dthack03's Avatar
Car Info: bugeye
If not, I have a obd2 code reader you can use to diagnose. Don't know if I could be of more help than that, but PM if necessary
