How much power from 87octane?
Old Sep 4, 2005 | 11:01 AM
Rosewood's Avatar
How much power could I get with normal aspiration and 87octane? Could any one give me an idea? I've already put a short ram and a new exhaust, I'm looking at new headers as well.
Old Sep 4, 2005 | 11:32 AM
Nick Koan's Avatar
Car Info: Legacy GT
on what motor?
Old Sep 4, 2005 | 03:06 PM
DLC's Avatar
DLC
Car Info: 2000 Leg GT LTD
Chaces are that your NA car recommended regular unleaded from the factory. Higher octane can increase power if the ECU is paying attention and advancing timing.
Old Sep 5, 2005 | 03:30 PM
Rosewood's Avatar
How much power from 87 octane
Yeah I guess that would help. I have the 2.2 in my legacy. I belive that stock it's around 130, 127hp.
What I really want to know is how far do y'all think I can get with just bolt ons and tweaking. I really don't want to go back to having a turbo.
Old Sep 6, 2005 | 10:10 AM
DLC's Avatar
DLC
You could, if properly done, get 150 or more crank horsepower if you did everything imaginable. This would include an exhaust, probably meant for something like the 2.5 RS Impreza from Borla, Stromung or Random cat, custom midpipe and muffler or perhaps an Impreza rear section. Intake should be MAF, with a sensor right by the air filter, so you'd be looking for something similar to the 98-99 MAF 2.5RS. Lightweight pulleys fit universally. Delta should be able to regrind your cams, which would help a bit after the previously mentioned mods. A lightweight flywheel and uprated clutch would help.
That's probably as far as you can go before needing to get the heads worked on, which can be as expensive as a simple turbo.
gruppe-s
Engine and Drivetrain
Nov 22, 2005 06:59 PM
gruppe-s
Nov 22, 2005 06:54 PM
skimobile
Jul 28, 2005 07:14 PM
antdiesel3
Nov 8, 2004 02:56 PM
Fulloutpwr
Mar 6, 2004 01:21 AM
