slow blow fuse problem
Old Aug 26, 2005 | 06:56 PM
thegnman's Avatar
I have a 97 Legacy 2.2 . I have just put on a new head and gaskets myself.
Had just one problem at first and had to change thermostat (it was stuck).
Restarted car I let it warm up found no leaks and the head gasket seems to have no leaks. I then took the car for a ride 4 blocks later it shuts off instantly. Traced it today to the sbf #2 (slow blow fuse)(engine control) tried another fuse in it , it blew, saw that coming. I was pulling around with alot of wires , and sensors.
Did I knock something loose? I'd appreciate any help at all , Thanks .
Old Sep 6, 2005 | 11:17 PM
ej20boost's Avatar
Car Info: My 2009 FIT for sale!!!!!!!!!!
get a wiring diagrahm....... check where sbf#2 is ...... then trace where the wires to the engine control(probably to the ECU)..... may have a pinched/shorted wire between there when you did the head job........ most likely.
queeg9k
Aug 23, 2013 04:41 PM
RallySportDirect
Engine and Drivetrain
Nov 24, 2009 12:54 PM
Ninosautoacc
Vendor Group Buys/Specials
Feb 24, 2004 10:39 PM
PimpRS420
Jun 9, 2003 08:17 PM
jasno999
Dec 3, 2002 09:14 AM
