Spare tire and FWD fuse?? Please help.
Old Dec 2, 2002 | 04:19 PM
jasno999's Avatar
Car Info: Blaze yellow WRX 2002
I have a flat tire and I put the spare tire on. My car is a manual WRX 2002. I read the manual and it is very hard to figure out. But it appears that I might need to insert a fuse in the fuse boox to dissable the all wheel drive system and enable just front wheel drive FWD.
Has anybody done this? How do you do it? What size fuse do you use? Do I need to do it with a manual or only with an automatic? My car is a turbo.
PLEASE HELP ME....
Old Dec 2, 2002 | 04:23 PM
McDade's Avatar
Car Info: 2000 RS Coupe/1990 Mazda Protege, zoom zoom..
only autos use a FWD fuse and it is for when the car is to be towed.
your ok
Jay
Old Dec 2, 2002 | 05:04 PM
jasno999's Avatar
Are you positive?
So I can drive my car with a spare on the rear and not worry about it?
Old Dec 3, 2002 | 07:42 AM
GOT_WRX's Avatar
FWD fuse trick only works on the automatics because they use electronically controlled center diff.
On the manual trans, it uses mechanical center diff -- there is no way to turn this off with just a fuse.(It involves more stuffs such as disconnecting the center diff)
I recall reading from the manual that if you use spare tire, don't drive it TOO long at TOO high speed, or your diffs will be fried, but should be ok for a short distance. Get your tire fixed asap!!
queeg9k
Aug 23, 2013 04:41 PM
nolan
Jul 10, 2013 12:13 PM
97impreza
Nov 30, 2006 03:22 AM
kafou33
Mar 6, 2003 12:52 PM
jasno999
Dec 3, 2002 04:13 PM
