Brake Pad Clank (help, please)
Old Aug 20, 2007 | 01:12 PM
nolan's Avatar
Car Info: 02 MBP wagon
I recently installed some Hawk brake pads on my 05 sti according to the hspn video guide (awesome how-to video). Anyways, everything went fine, but i noticed that when i go in reverse for a bit, then brake, the pads click like they're sliding back and clanking against the inside of the caliper. Then if i brake while driving forward again, they will slide forward and clank against the front side of the inside of the calipers. After that, its cool, but everytime i go in reverse and brake, the same thing happens.
Anyone know how to keep the pads in place so they're not sliding back'n'forth?
Any help would be much appreciated.
Old Aug 28, 2007 | 03:39 AM
theSTI's Avatar
I have the same thing happening with my car..from what i read this is normal. when your reversing the pad angle a certain way, and when you go forward again they reangle themselves for forward braking, if im correct. I was hearing the same noise even before i changed to aftermarket pads. hope this helps.
jeff
Old Aug 28, 2007 | 08:34 AM
nolan's Avatar
Thanks, Jeff.
So I guess you just have to deal with the sound? I can deal with it as long as I know I'm not damaging my brakes/rotors everytime I go in reverse/forward again.
Did you find a fix? Or do you just kinda deal with it?
Old Aug 28, 2007 | 01:41 PM
charlesj's Avatar
Staff Member
Car Info: 06 STI
Yeah, hawks do that. I just dealt with it. Antisqueal helps, but they will still do it
Old Aug 29, 2007 | 09:14 AM
nolan's Avatar
Thanks guys,
I can deal with the noise as long as know i'm not slowly destroying my calipers. Do you happen to know of any pads that definately DONT make this noise so I can try them next time?
Old Aug 29, 2007 | 09:31 AM
charlesj's Avatar
Staff Member
Car Info: 06 STI
Its a problem on several pads, but Hawks are particularly known for it. You dont have to worry about hurting anything. I put about as much of a beating on mine as possible.
Great pads to go with next time are Pagid or Ferroda
Old Aug 29, 2007 | 01:30 PM
grambo's Avatar
Car Info: '06 CGM STI
The Stoptech Posi-Quiets do teh same thing on my STI. Its pretty normal, annoying, but normal..
Old Aug 30, 2007 | 10:08 AM
Deserted1's Avatar
Car Info: 06 STi
i had the same issue, but i tightened up my ebrake a bit and it went away.
Old Aug 30, 2007 | 10:24 AM
grambo's Avatar
Hmm good call^
I'm gonna' try that when I bleed them again.
Old Sep 7, 2007 | 01:12 PM
nolan's Avatar
Thanks guys.
How do you tighten the ebrake?
dchou7
Feb 27, 2006 06:35 PM
wterry
Jul 14, 2005 09:28 AM
scritch
Jan 17, 2003 08:24 PM
