General Tech / How To's / Installations Technical discussions about the USDM 2008+ WRX and WRX STi.
oil change
Old Oct 12, 2011 | 07:02 AM
urabus32793's Avatar
Car Info: 1995 Subaru ImprezaL AWD
oil change
i have 95 impreza 150,000 miles. I cant decide if i should go with normal oil or synthetic. i have heard synthetic is better, but i dont know why. Also should am i supposed to use 10w-30 or 5w-30
Old Oct 12, 2011 | 09:05 AM
04GG's Avatar
If in doubt, FLAT OUT
WRONG FORUM.
If it isn't turbo, you probably don't need synthetic. Synthetic doesn't break down as easily, doesn't foam, tends to flow better at start up, etc... As long as you are changing at appropriate intervals and use something other than el cheapo oil, you should be fine.
150K is lowish for a 95. My 97 has 208K.
Old Oct 12, 2011 | 04:56 PM
04caliwrx's Avatar
its also bad to change on a car with 150k
Old Oct 13, 2011 | 10:30 AM
04GG's Avatar
It is potentially risky, but I've done it before on my S13 and didn't have any problems with it. Once you switch, you'll want to stick with it too.
Old Oct 19, 2011 | 08:52 AM
jagan323's Avatar
Car Info: 2006 Subaru STI
The fear from changing oils is a total myth. It's a marketing scheme designed to make u loyal to one brand. It has been myth busted by Bob The Oil Guy. If you want to learn more about oil, and I mean EVERYTHING, search Bob the Oil Guy =)
For a car with such high mileage, definately go to synthetic. 5w30 would be recommended, although if you go with German Castrol Syntec, you can go 0w30. I've heard it's one of the best synthetic oils around. I'm personally trying it out on my next change. Goodluck.
Old Oct 19, 2011 | 04:22 PM
04GG's Avatar
Not changing from one brand to another, changing back to fossil oil after switching to synthetic. Some seal materials may not like going back and forth between types.
Old Nov 11, 2011 | 12:02 PM
calves's Avatar
Car Info: 08 STi
don't they make synthetics specific for high mileage cars? Maybe that would be an appropriate start/bridge before going regular synthetic?
Old Nov 14, 2011 | 11:13 AM
04GG's Avatar
I highly doubt it makes any difference difference if they call it "high mileage" or not, they are likely the same thing just with different additives. I've done it on a few of my previous high mileage cars and never had an issue. If the car was well maintained and isn't currently leaking, it will probably be fine.
Old Nov 14, 2011 | 11:20 AM
Hoofus's Avatar
Car Info: subaru legacy, 01 4eat
speaking of my od just rolled over to 150000 while on a trip from pittsburgh.
salvator_rizzo
Jul 10, 2009 04:10 PM
nation
Apr 17, 2009 01:16 AM
yzercyber
Mar 2, 2008 06:02 PM
Fa9-Wrx
Apr 29, 2007 08:17 PM
evsoul
18
Oct 26, 2006 12:44 AM
