DIY: Paint wheels
Car Info: 2010 997.2 GT3
DIY: Paint wheels
1. Remove the center caps
2. Tape and cover wheel weights
3. Clean and degrease everything thoroughly
4. Sand the inside with 200 grit paper
5. Wipe with a cloth
6. Tape the lug hole areas
7. Mask the tires and valve-stems
8. Then line up your index cards
9. Primed the inside with 2 coats of self etching primer
10. Primed everything with primer/filler
11. Sand everything with 200 grit paper again
11. Wipe with a cloth again
13. Spray on 2 coats of (choose your color) Wheel Paint
14. Sand with 800 grit paper
15. Spray on 2 more coats of (choose your color) Wheel Paint
16. Spray on 3 coats of Duplicolor wheel clear coat
17. Let them dry for 24 hours
DONE
BEFORE
AFTER
DONE
BEFORE
AFTER
Thanks Jourdan!
Haha I saw that but I decided to make a thread in the GH section and start throwing all of my DIYs in here.
If in doubt, FLAT OUT
Nice job.
One thing I might actually recommend is also masking the spots where the lugs seat. Paint on there can chip and allow the lugs to loosen.
sjscooby
Apr 21, 2011 07:25 PM
tekgnosis
14
Sep 7, 2006 05:21 AM
