Strange idle problem
Old Sep 28, 2004 | 10:11 PM
scoobsport98's Avatar
Car Info: 98 Impreza Outback Sport
I always thought my radiator was always on... and I haven't noticed it "blowing air"
you mean AC?
Someone please fill me in if I'm off here.
Old Oct 1, 2004 | 10:01 AM
OKsubaru's Avatar
Car Info: 1999 Rally Blue Pearl Subaru Impreza 2.5 RS
My 99 Impreza does something really similar, I have a post on this forum a few spots down. Someone on the forum reccomended that I replace the mass air flow sensor. There happens a recall on this part for my model, and I'm getting that taken care of soon so if it helps I'll let you know. Other ideas I've heard include bad spark plugs and an improper air/fuel ratio.
Old Oct 5, 2004 | 10:45 AM
OKsubaru's Avatar
I got my MAF replaced yestarday and it fixed the problem right up. When my car would do that I would sort of hear something "switch on" under the hood as you put it, and then the rpms would start going nuts. It sounds really similar to what you are describing, so maybe look into that. Swapping out the MAF is really simple- find someone with a similar model/year that uses the same MAF and pop in in your car for a few mins and see if that does the trick. Hope this helps.
Old Oct 7, 2004 | 08:06 AM
OKsubaru's Avatar
MAF and AFM are the same thing... I guess it has lots of names. They are pricey if you get them from Subaru (~$250+). You can find them used on eBay though for much cheaper, probably around $70-$80. They are very easy to switch out, if you have ever put in an intake, you've practically done it before.
Old Oct 8, 2004 | 10:23 AM
OKsubaru's Avatar
You're probably right, I've always heard mine referred to as the "mass air flow sensor" though.
Old Oct 10, 2004 | 10:18 PM
joltdudeuc's Avatar
Old School
Car Info: '99 RBP GM6
The part number: 22794AA000 Air Flow Meter sensor only (courtesy of peaty)
This is about $50 from your dealership, and you can install this in about 15 mins if you have a flathead screw driver, pliers, and 12mm socket (wrench with extension needed to unbolt airbox from car)
Check it out here http://www.scoobymods.com/forums/showthread.php?t=414
-Gagan
Old Oct 13, 2004 | 06:02 AM
XenoWolf's Avatar
Car Info: 1984 Subaru GL Wagon/1999 Subaru Impreza L Wagon
The MAF Sensor is an insturment for measuring airflow.
Also I'm guessing it's an electrical problem as well. If you can find a multimeter you should test various points around your cars electrical system to see if the voltage fluxuates when the fans kick on.
Is the idle problem happening at the same exact time the fans kick on/off? If there is some delay I'd also suspect your temperature sensor. (The fans might be kicking on too late, causing the car to overheat.)
draconicgrin
Dec 12, 2006 10:59 PM
MVWRX
Mar 22, 2005 12:09 PM
STI Stan
Jul 19, 2004 12:35 PM
yodler
Mar 5, 2004 11:06 AM
