Removing Silencer On The Intake
Old Jul 23, 2003 | 01:50 PM
AWD OWNZ U's Avatar
Car Info: 2000 2.5RS
What year is your car?
Old Jul 23, 2003 | 02:21 PM
mysubaruimp's Avatar
Car Info: 2001 sub. imp.
Originally posted by LB2.5rs
It is a 2000 2.5rs. I found some pictures of how to remove it, but im not sure of the year. I think its a 99. And if i were to remove it, it wouldnt screw up the car or anything right?
it is the same method on a 2000 as on a 1999. it wont do anything to your car except add a little bit of noise at WOT and flow a little more air, completly safe, and fool-proof. well, unless you remove the filter thinking its the silencer, but then you shouldnt really be working on cars
Old Jul 23, 2003 | 03:18 PM
AWD OWNZ U's Avatar
There is no intake silencer on a MY00/01. That's why I asked. Time to make your own intake. Pull all the tubing off from airbox (the blue arrow). Goto home depot and grab some dryer ducting and a hose clamp. Slip it over the outlet from the airbox and run it into the fender. It might not look the best, but trust me it works.
JC
Old Jul 23, 2003 | 05:27 PM
AWD OWNZ U's Avatar
Shouldn't cost you more than $5. Less if you use duct tape like I did. You forgot girlfriend payments. I'm surprised you can afford a car.
Old Jul 23, 2003 | 05:34 PM
The dryer duct intake is as effective as almost any method. If you are concerned about it not being pretty, you can always replace it later with a $55 PDM intake (under Subaru Corner at www.pdm-racing.com ). Mechanically, it is the same as a Ganzflow/PDM style intake to follow JC's advice.
ianalex
46
Jun 6, 2005 05:39 PM
bsakattack
May 20, 2004 10:18 PM
Wrxplaya11
Dec 31, 2003 04:56 PM
Sti-nkinPhast
Aug 22, 2003 12:12 AM
NRTmotorsports
13
Jan 24, 2003 09:47 AM
