power loss
Car Info: silver 2.5 tr 2006MT wrx
power loss
i am losing power at times when i take turns sharp, from a dead stop, why is this happening, in the winter i thought i had ice in the tank but, it is happening now, it seems to happen also on off and on ramps to the highway if i am going fast, why does it do this is their pressure loss in the fuel system? should i get a different fuel pump, i have no real mods done to the car.
I have same problem starting from 0 mph. feel like a binding of the tranny in mine its just bind up for second like wheel is stuck. But i found the problem my right front motor mount is broken up pretty badly. see if you put brakes on in ger give it gas does engine move up on one side or other. second check for visable damage.
Originally Posted by Miotch
Fuel issue
just my observations:
at fuel 100% full I get decent power.
at around 80% I get most power
at around 50% I loose power
at around 30% I loose the most power
at around 20% I gain some power again.
mmboost
Jan 9, 2004 11:25 PM
