Plugs,Trans, and Rear Differential
Old Oct 6, 2003 | 06:53 PM
nodoz781's Avatar
Car Info: VW
I know there are other topics out there on this and This might be better in the Transmission Forum. I cant seem to find all the answers for the ?'s I have. Sorry if Iam asking ?'s that have been beaten to death......
I have a MY02 2.5 RS 5spd M/T, Iam going to change my plugs, Trans Fluid, and Rear Diff. Fluid. I need to know:
1) Wich are the best performance plugs to get for a MY02 2.5 RS?
I dont expect gains or anything but do want the best plug I can get for my car.
2) Wich brand and type of Trans Fluid , without having to add shock oil, Seems to provide the best results as far as smooth shifts, good protection (ecspecially in Hard/Fast shifting conditions).
3) Which brand and type for the rear diff. that meets the same criteria? Can I use the same Fluid in the Rear Diff. that I put in the Trans?
4) How many Quarts of Trans fluid does the 5spd M/T hold? Also, how much does the rear diff. hold?
I really appreciate your time to read and respond to my ?'s.
-Ryan
Old Oct 6, 2003 | 08:46 PM
1) NGK coppers, part number BKR7ES-11
2) Factory gear oil. If you really want synthetic, make sure it's a GL5 fluid and has limited-slip additives to help the synchros. Really good synthetic gear oil is actually too slick for Subaru gearboxes, which depend on some friction for the synchros to work properly.
3) Whatever you put in the gearbox, put in the diff too.
4) 3.7 quarts gearbox, .8 quarts. You'll need 5 total obviously, with a little leftover.
Old Oct 7, 2003 | 01:10 AM
nodoz781's Avatar
Car Info: VW
thanks ban, 1 more thing, what would you recommend I use for trans fluid? I mean what do you use? Thanks
Old Oct 12, 2003 | 10:12 PM
I'm still on the stock fluid, but I am about to switch to Redline Lightweight Shockproof. From what I have read and heard, it is the best choice for helping the synchros work better, which is more important in my mind than the absolute lowest coefficient of friction on the bearings and gears.
I also might use regular 75w90 Redline GL5 fluid first so I can compare the differences.
Old Oct 14, 2003 | 12:17 AM
Call around and see if you can source it locally. If you have to buy it direct from Redline it will cost you more for international shipping and potentially customs. Lachute may carry it, and if not, it would be a good time for them to get a wholesale account.
Bagin,DVS
Mar 25, 2008 10:22 AM
Teriyaaaaki
Hawaii Classifieds
14
Oct 24, 2007 05:45 PM
bluebiker
Jun 22, 2006 10:41 AM
Subaru Tard Eli
Nov 29, 2005 05:49 PM
psychobooe
Jun 15, 2003 08:33 PM
