Older (non-RS) Impreza swaps?
Old Feb 8, 2003 | 08:26 PM
Keep searching here and on NASIOC.com, Mr. Thorsen. There are soon to be quite a few EJ25s lying around after WRX/STi swaps. Or, a cheaper and possibly simpler route would be to find an OBS with the 2.2 liter. It had 140 hp, and almost everything that fits a 2.5 will work for it too. Or, you can find a 2.2 almost anywhere dirt cheap for swap into an older impreza or OBS with 1.8 liter. Either way, I agree that it is a perfect beater! If I hadn't lucked into my 280ZX, I would be on exactly the same hunt as you. Good luck!
Old Feb 9, 2003 | 06:38 PM
RSEnigma's Avatar
Car Info: fastar
check http://www.i-speedusa.com/home/ never dealt with them but from the looks of it they know wut they're doing and it never hurts to ask. also as an engine to look for as an option is the forester's 2.5 (i think its the same as the rs...)
Old Feb 10, 2003 | 01:22 AM
I believe the mount points and transmission hardpoints are universal, but like above, Bill at i-Speed can tell you. He's Skywalker here on i-club.
Old Feb 11, 2003 | 10:23 PM
Kostamojen's Avatar
NASIOC Slut
The problem with doing the tranny is well is that you have to convert everything to hydrolic. I say just stick with the stock tranny and toss in the engine... If the tranny explodes some day, THEN do the swap.
Oh, and the STI tranny mount WILL NOT bolt up with the EJ18 tranny mount, as the mount and braces are different. (The EJ18 tranny has one brace as opposed to 3 for the newer cars)
The Motor mounts on the other hand fit just fine.
Old Feb 12, 2003 | 07:45 PM
Originally posted by N/A
Just get an entire front clip from Japan from another WRX wagon (GF body) and get the needed rear diff and axles. Then swap everything over. If your going to do it at least make it worth your time and effort.
That would of course produce a superior car, but would require a superior budget as well. Pretty much any Impreza swap will have relatively equal bang-for-the-buck ratio, considering the price differences between a 2.2, an EJ25, and an EJ20T.
HomerJay
Oct 31, 2004 08:38 AM
Khamz
Jul 6, 2004 10:22 AM
AllWheelGo
Wanted
Mar 4, 2004 01:23 PM
S-Squared
Jan 5, 2004 07:49 PM
Shin
Aug 22, 2003 12:01 PM
