Motor Bogging while cold
Old Oct 14, 2003 | 12:19 AM
The problem is probably due to the fact you are running an OBDII engine with an OBDI Ecu, probably. You may be having compatibility issues with EGR and open loop running.
Old Oct 14, 2003 | 10:56 AM
Ah, there's the likely problem. It still thinks it has the smaller injectors. Try using an SFC and see if you can fix the problem. If you have access to a dyno, you might even be able to get another 8-10 hp out of the engine that way, even without other bolt ons.
rodrigo
13
Aug 25, 2023 01:09 AM
Bagin,DVS
Nov 28, 2005 12:20 PM
Juelz5420
14
Sep 16, 2005 10:46 AM
shaggyone
Oct 26, 2004 02:47 PM
verc
Jul 10, 2003 08:18 AM
