engine bogging during acceleration in turn
Old Nov 14, 2005 | 08:13 PM
Bagin,DVS's Avatar
Car Info: silver 2.5 tr 2006MT wrx
Question engine bogging during acceleration in turn
my engine boggs at around 4k rpms in tight turns during acceleration.
say i am in 2nd gear 3k floor it in a turn as i reach 4k 80% of the way through a turn it bogs engine drops rpms, or holds them but there is no acceleration. i have to let of the throttle and hit it agian it hesitates then takes off. it has done this with a tank of gas at full half quarter. highway on ramps it does it when you are getting on, now it does not do it in straight line drive. dead stop all th way up to 100. no problem just in turns.
also it did it in the winterat around 4k rpms i thought there was water in the lines so i dumped in isospropyl alcohol. it worked but not all the time.
am i losing fuel pressure is there some kind of yaw sensor in there or what.
or is there some other type of bull **** going on.
Old Nov 15, 2005 | 10:36 AM
Checkpoint's Avatar
Car Info: 00 RS
*Check your motor mounts and tranny mounts. If the drive train is rocking that may contribute to a miss alighnment.
*Check the control arms and alighnment. You don't want a half shaft cramming into the tranny. Also, if your camber is changing due to bad bolt care they may end up rubbing against your suspension. Do you have after market suspension?
*Check your fluids naturally in the tranny
*Check to see if your tires are the same size all the way around. Your subaru doesn't like different tires.
*Any noise from the tranny? Any codes?
Also, sump chambers run around $250. This will help keep fuel going to the motor.
Is it coughing or just losing power?
Mitch
www.cp-racing.com
Old Nov 17, 2005 | 05:22 AM
AWDimprezaL's Avatar
this happend to me when my maf was bad, perhaps a plug wire is loose.
Old Nov 17, 2005 | 09:51 AM
Checkpoint's Avatar
Car Info: 00 RS
hmmm.... wouldn't have guessed
Old Nov 19, 2005 | 09:49 AM
Bagin,DVS's Avatar
i do not think there is a mas air flow sensor on this rs, i know there is one on the 2001,
Old Nov 28, 2005 | 12:20 PM
97L/2.2?'s Avatar
Car Info: 97L impreza 2.2
It's easy to tell if has maf its sensor box right the intake
its black.
rodrigo
13
Aug 25, 2023 01:09 AM
SlickmisterN
Mar 15, 2019 04:06 PM
WhiteLghtning
Jun 28, 2011 03:28 PM
picturegeek@sbc
Oct 2, 2007 07:50 AM
