Map or Maf?
Old Jan 4, 2009 | 11:16 PM
T-cel89's Avatar
Car Info: 1999 Impreza L
Map or Maf?
Does the 99 EJ22 intake use a map or maf sensor. I am looking for an intake, but most suggest i stick to stock due to problems with the MAF sensor, but map should be ok. Any help on this would be greatly appreciated. Thanks in Advance.
Old Jan 4, 2009 | 11:20 PM
dubyuHO4's Avatar
Car Info: AWD Peanut "i" IMPRETZA
Map Iirc
Old Jan 5, 2009 | 12:05 AM
T-cel89's Avatar
Thats what im thinking. But im still not sure. If it helps any one else my Air filter is mounted just before the throttle body not in the fender well.
Old Jan 14, 2009 | 08:58 PM
sean2.5black's Avatar
You gots both.
The map sensor just reads your negative pressure though, thus throwing a CEL if you boost it.
The MAF sensor is right before the big black box (intake).
If you get an aftermarket intake, all you need to do is get an adaptor... Which you can find at your local auto store... Vibrant makes them, and they're about 10 dollars.
carletto
Jul 23, 2005 03:20 PM
rsracer2005
18
Aug 29, 2004 02:50 PM
Guerra
Jul 18, 2003 09:49 AM
RSEnigma
Feb 28, 2003 06:33 AM
