Intake Question for my 2005 rs MAP or MAF
Old Aug 11, 2004 | 10:47 AM
rsracer2005's Avatar
Question Intake Question for my 2005 rs MAP or MAF
do i have map or maf on my 2005 2.5rs? i thought it was MAP but someone in a naisoc forum said they went back to maf in 2004. im really confused bc i was planning on buying a cobb cai soon. could anyone clarify if i have map or maf. thanks a lot.
Old Aug 11, 2004 | 10:56 PM
RoadSpike's Avatar
The 2004 are still MAP sensors
I don't know about the 2005 but i doubt they have changed the way the intake is setup yet. If you could take a picture of your intake systemt that would be great.
A maf sensor looks like this (well sorta had to resort to an old turbo'ed model but the mas air flow sensor is clearly visable just before the big cone filter)
A cobb CAI on a 2004 looks like this (no MAF)
Old Aug 12, 2004 | 09:03 AM
Kostamojen's Avatar
NASIOC Slut
2005's are MAF, that is correct. You can see it in this pic: http://community.webshots.com/photo/...44544802TDVxMJ
You will probably have to either modify a cobb intake, or wait for a new redesigned one. Modifying one to fit shouldnt be to hard, you just need to cut a segment out to fit the MAF and probably need a MAF adapter for it as well.
Old Aug 12, 2004 | 09:06 AM
heres a link to a picture of na 05 engine.
http://subaru.com/servlet/research?m...command=photos
Old Aug 12, 2004 | 09:08 AM
Kostamojen's Avatar
NASIOC Slut
You can see the MAF sensor in that photo as well.
Old Aug 25, 2004 | 01:26 PM
Kay95's Avatar
i wonder if the 05 intake manifold flows any better than the current alloy and composites intakes
and where is the coil pack at? or is it now coil on plug?
Old Aug 25, 2004 | 02:56 PM
Kostamojen's Avatar
NASIOC Slut
Yup, the 05 intake manifold flows better. I dont know about the coil pack though, have to look to be able to tell.
Old Aug 25, 2004 | 06:35 PM
Defiantguy's Avatar
Car Info: 2004 Subaru WRX
I'm just glad they are not plastic anymore.
Old Aug 26, 2004 | 11:59 AM
Kay95's Avatar
what is bad about the plastic manifold?
Old Aug 26, 2004 | 06:34 PM
Defiantguy's Avatar
it just looked cheap to me, though I hear it flows better than the metal ones on the previous RS's. Don't think it would hold up to turbo too well though.
Old Aug 26, 2004 | 08:24 PM
Kostamojen's Avatar
NASIOC Slut
Wait, the 05 isnt plastic, it was the 04 that was plastic. This is the 05 Intake manifold, and yes it flows better: http://community.webshots.com/photo/...44545129Fknpbp
Old Aug 27, 2004 | 11:54 AM
Kay95's Avatar
the composite manifold should have no problem with the heat of a turbo because if it would melt at 300 degrees F then at 200-220 under hood temps would weaken it to the bending point so the temp it would take to melt it would have to be in the 400s to ensure that there would be no problems later for subaru to have to recall
why do the legacy and impreza manifolds look different?
because it looks like a H4 in both cars but the legacys is much different
Old Aug 27, 2004 | 06:26 PM
Kostamojen's Avatar
NASIOC Slut
The 05 Legacy has some models with the PZEV motor. There are like 3 variants of the N/A 2.5 right now for the 05 model year.
Old Aug 28, 2004 | 09:44 AM
Kay95's Avatar
do you know any specs of the different motors?
Old Aug 28, 2004 | 02:14 PM
Kostamojen's Avatar
NASIOC Slut
Well the legacy equiped non-PZEV 2.5 with the nice new intake manifold makes a couple more HP than the normal 165, but aparently its because of the Legacy's dual exhaust. The 2005 Forester has the same old 2.5 from before, while there is the PZEV motor in some of the Legacies which makes like only 162hp, and has 3 cats and a very different designed intake manifold.
