ignition timing (not subaru)
Old May 22, 2003 | 10:57 PM
philioWRXman's Avatar
Car Info: 1998 Chevy S10... lowww
ok, 1998 Nissan Frontier
2.4L I-4
i am trying to find the optimum power output for the timing.
i turned my distributor cap at idle and got several results, as expected, and ended up leaving it all the way to one side (there are guards that only let it go so far) and its at a higher idle rpm now.
also, after about a half day of driving, my gas mileage is obviously way down and the exhaust tip is blacker than its ever been.
is this over advanced or retarded? im not sure which it is.
how can i know what the maximum power output will be?
comments welcome, good or bad.
Old May 24, 2003 | 01:42 AM
ok, i set it back to the stock 20 degrees BTDC and it ran a lot better. my mileage was crap though still.
i also filled the tank tonight. it accelerated and idled a lot smoother after that, i think i may have had a bad tank of gas.
may i have ****ed my valves up or my injectors by getting them carbon fouled or something?
i want good mileage, i drive a lot.
Old May 24, 2003 | 10:25 PM
Run some injector cleaner through it, and get Chevron for the next tank or two. If it is fouled up, the stuff will come clean, shouldn't be too hardened. It was definitely running rich though to compensate for the advance.
Old May 25, 2003 | 01:37 AM
yea thats what im doing tommorow.
getting the Fuel Injector service done at work.
plus, kevin, i dont like chevron. ive always gone to arco.
Old May 25, 2003 | 10:42 AM
If you won't go to Chevron, go to 76 or Shell instead. Chevron charges more, but they sell good stuff. Those 3 have the cleanest fuel, they leave less deposits. Arco is just like the other 'discount' stations- they buy the cheapest gas someone will sell to them. In your truck, it's not normally a big deal, but in a motor you really really care about, run the good stuff. Anyways, a tank of Chevron is just like running a bottle of injector cleaner.
neubaru
Oct 21, 2004 07:45 AM
ziggydikface
Aug 9, 2004 11:07 AM
mr. m
Sep 2, 2003 11:43 AM
