Help please - Taking off underdrive pulley
Old Jul 23, 2006 | 12:13 PM
2point5AWD's Avatar
Car Info: '08 FXT Dark Gray Metallic
I'm taking off the underdrive pulley from my 2000 2.5RS
When I use my breaker bar to unbolt it, it just turns the pulley. I had someone sit in the car and hold the break but I don't think it did anything... should I try again? I don't have an impact gun unfortunately.
Any other suggestions?
Old Jul 23, 2006 | 07:33 PM
RewSupul's Avatar
Car Info: '06 Impreza 2.5i
This is what i found hope it helps
crank shaft.. depends on if you have a manual or an automatic.
if you have a manual put it in gear (1st or reverse) pull the hand brake on then loosen the bolt. If you have an automatic take off the inspection cover for the timing belt on the drivers side. the cam shaft pully should have 'spokes' on it.. take some heavy wire and run it thru one of the spoaks and around a bolt on the block and wrap it a bunch of times, the loosen it up.. this method works great if you are planning to replace the timing belt... if not i would suggest finding another way to do this because you run the risk of the timing belt slipping a tooth or overstressing the belt, thus weakining it..
as far as the alturnator... take it down to a local auto parts store and find the youngest kid working there and ask him to pull it off for you..
Report Bad Post Reply With Quote
https://www.i-club.com/forums/showth...ighlight=pully
Old Jul 24, 2006 | 05:34 AM
AWDimprezaL's Avatar
get a huge breaker bar, rest it on the frame rail, unplug your coil pack, crank it over...wallah, worked for me
rockforevr77
Apr 5, 2006 05:13 PM
QuickShift
Mar 26, 2004 09:11 AM
FlaBrit
Feb 13, 2003 04:16 PM
FlaBrit
Feb 8, 2003 08:22 PM
QuickShift
Dec 13, 2002 09:57 AM
