Engine races (high idle when cold)
Old Nov 5, 2007 | 07:52 AM
bwlfe's Avatar
Car Info: 2003 2.5 RS 5 speed
2005 Impreza 2.5 – five speed standard
When the engine is cold and I move the car in reverse, it frequently races to 2000 or sometimes 3000 rpm’s for several seconds. My foot doesn’t have to be on the gas pedal for this to occur. The increase in engine speed happens when I touch the brake to stop the car.
For instance when I back the car out of my garage in the morning (on the level) I will put the car in reverse, release the clutch and let the idle speed move the car backwards (MY FOOT IS NOT ON THE GAS PEDAL AT THIS TIME). After the car is out of the garage, I will then depress the clutch and apply the brakes (MY FOOT IS STILL NOT ON THE GAS PEDAL) -- when I apply the brakes, the engine increases in speed.
The condition is more prevalent if I do this on a steep grade (front of the car facing uphill). Also, is seems to be worse in the wintertime when it is really cold. Also in the wintertime, in addition to racing at start-up, the engine will race between gearshift changes. After a few minutes when the engine gets warmer, all these symptoms stop.
I have tried tapping the accelerator as I back out of the garage, hoping that might eliminate the problem – it does not. Also, the engine must be completely cold for this phenomenon to occur. In warmer weather the car must be parked many hours until the engine returns to ambient temperature before the problem returns. In the winter when it is cold outside and the engine can ‘cool down’ in several hours, the problem will return. The problem however is not consistent – it might not happen for several days and then suddenly start again.
Though the problem mostly occurs when the car is faced uphill or on the level, it sometimes occurs when the car is facing downhill.
I’ve had the car checked several times at the Subaru dealer where I bought it. They can not find the problem. They even checked with Subaru Of America for advice or any download updates to the engine computer that might solve the problem. It appears there is no (known) solution to this problem.
Any suggestions?
Old Nov 5, 2007 | 08:18 AM
03_Impreza_Al's Avatar
Has your engine warmed up before you move it or are you moving your car when its still cold
Old Nov 5, 2007 | 10:01 AM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
isn't there an adjusting nut on the throttle cable? adjust that. reset your cpu. or faulty mass air flow sensor..
Old Nov 5, 2007 | 03:45 PM
bwlfe's Avatar
The engine is cold when the malfunction occurs.
Old Nov 5, 2007 | 03:57 PM
suby guy's Avatar
Car Info: 05 aspen white 2.5RS
I wouldn't call it a malfunction, the engine is just trying to warm up.
my 05 RS dose it to when I first start it up in the morning.
Old Nov 8, 2007 | 06:12 PM
CrazedPanda's Avatar
Car Info: 2006 Impreza 2.5i
If im leaving work my 06 2.5i will rev up a bit when clutch in and stop. it sounds like its just cause the motor is "cold"
Old Dec 5, 2007 | 03:11 PM
milom80's Avatar
Car Info: impreza wagon!!!
Its called a fast idle cam. It just helps your engine warm up. Not anything to worry about.
BOSS679
Jun 17, 2006 11:52 AM
jmerrellutah
Feb 12, 2006 11:39 AM
PtownWRX
Oct 24, 2005 07:56 PM
fixmuflym
Dec 13, 2004 06:36 PM
j.reed
Dec 5, 2003 01:31 PM
