best way to clean ur IAC??????
Old May 27, 2005 | 07:49 PM
scoobie555's Avatar
anyone know how to clean the iac control valve? not just the spout/tip i mean inside it as well. gunk does get inside and slows down the stepper motor screw. wnat to know how to clean that????
Old May 27, 2005 | 08:36 PM
Kay95's Avatar
take it out and spray the **** out of it with carb cleaner and blow out with compressed air
its what all the xt-6 guys do
Old May 28, 2005 | 01:00 AM
VIBEELEVEN's Avatar
Car Info: 03 WRX
I had a problem with the iac in my 03 wrx a few months ago, tried cleaning it an ended up needing a new one.
Old May 29, 2005 | 07:11 AM
scoobie555's Avatar
yeah im kind of leary about sraying the f*** out of it because im sure the coils inside are coated with some type of weather/corrosion proof protectent and the cleaner will clean it right off causing it to short or ground out.
input????
Old May 29, 2005 | 07:58 AM
Kay95's Avatar
the motor is a sealed unit and spraying into it will not harm it because if it would dont you think that the oil would cause a short first?
Old May 30, 2005 | 06:21 PM
scoobie555's Avatar
thanks for ur help, but they are not sealed. thats the main cause of iac to go bad is all the grim, gunk, getting inside(right behind the tip) on the stepper screw it self where the threads of the screw is and causing it to not move or move slower than the ecu wants.
if u have oil that makes it in ur throtle body to ur IAC thats a prob.
sealandsheep
Jul 15, 2014 10:19 PM
Masanori
Aug 17, 2013 01:10 PM
slim617
Oct 31, 2007 04:50 PM
v1rus67
Subaru OEM Parts For Sale
Dec 12, 2003 08:40 AM
andyC
Mar 31, 2003 09:18 PM
