Will I be reaching 350whp?
Old Apr 8, 2012 | 10:57 AM
  #46
azer408's Avatar
Car Info: 2006 CGM Impreza WRX/ 1998 RBP Impreza 2.5RS
Just put everything on get a conservative tune to make it safer and increase drivability and call it a day while you save up for a shortblock build
Old Apr 11, 2012 | 02:08 AM
  #47
E85FTW's Avatar
Car Info: Subaru STI
I'd rather drive the **** out of it, if I'm already heading towards a rebuild..
Old Apr 15, 2012 | 08:19 AM
  #48
Heedz's Avatar
Nobody likes the tuna here
Originally Posted by EQ Tuning
I don't believe the problem has been fixed. I still see much more instances of ringland failure in 09+ cars than in pre-07 cars. Even cars that have been running a Cobb OTS map or various tuner's custom tunes since nearly day one seem to have the potential for ringland failures. It's basically a crap shoot. If you get lucky and happen to get 4 well cast pistons your engine will hold up to good power and last a long time. If you get unlucky, however, a few knock events from bad gas or heat soak can take out a ringland with very low mileage no matter what mods or tune you're running.
-- Ed
Hmmmm this is a big problem here!!!
So its just not the AVCS adjustments not going smoothly. It seems like its only with 257s but do you see any 255s having the same issues?
Yeah agreed
Well driving it like that is just asking for other things to be taken out with it. Just because its a conservative tune doesn't mean you cant drive it hard. I'm on a very conservative one so my MPG isnt the best but its providing more than enough power.
Old Apr 15, 2012 | 10:05 AM
  #49
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
It has nothing to do with AVCS at all and yes, EJ255's suffer from the same issue. I have found that more 255's tend to make it to higher mileage but I believe that's because they tend to run smaller turbo's, less power, and are not driven as aggressively on average as 257's.
-- Ed
Old Apr 15, 2012 | 05:45 PM
  #50
Heedz's Avatar
-- Ed
So if its pre the date you mentioned less issues, so not found in earlier model LGTs then.
Old Apr 25, 2012 | 08:19 PM
  #51
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Correct... pre-06 cars tend to hold up longer. That being said, its not a guarantee.... the ringlands are still the weak point of any stock EJ25 turbo.
-- Ed
Old Apr 26, 2012 | 02:35 AM
  #52
Heedz's Avatar
-- Ed
Hmm just a bit better of a batch but still weak. 2.0L ftw
Old Apr 26, 2012 | 12:15 PM
  #53
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
2.0l has it's own issues . No motors are bullet proof until they're built up well.
-- Ed
Old Apr 27, 2012 | 01:27 AM
  #54
Heedz's Avatar
well 2.0 referring to the 207
Old Apr 27, 2012 | 07:57 AM
  #55
Coastie1983's Avatar
Car Info: Subaru Wrx Sti 2005, 2012 Silverado, 2013 ZX-10R
I had Ed tune my car and I wanted to only run 20 psi for now until I build the motor this summer. We hit 350whp with the following mods: APS 725fmic, Walbro 255, Hallman MBC, HKS turbo back exhaust, Helix downpipe, ATP GT35 w EWG setup tial 44mm wastegate, DW1100cc injectors, Cobb intake, Cobb accessport V2, ACT HD clutch, Fidanza flywheel, Cobb short throw, GFB alt pulley, Gates alt belt, cold step spark plugs, HKS bov. We are hoping to hit 850whp after the build this summer.
Old Apr 27, 2012 | 07:59 AM
  #56
04caliwrx's Avatar
850whp come one haha your gonna have to put one hell of a turbo on that thing
Old Apr 27, 2012 | 11:18 PM
  #57
johnson7's Avatar
Car Info: bmw
hing 350WHP with the set up I purchased. I cant install it just yet since I purchased the car from an auction, and it needs some body work to get done first!
topdog
30
May 6, 2007 11:20 AM
ADAMnQuickFXT
Wanted
Feb 3, 2005 02:04 PM
Mosh
22
Oct 23, 2003 01:34 PM
andyC
Mar 31, 2003 09:18 PM
