Up Pipe Installation Needed
Old Apr 5, 2007 | 06:08 PM
1sicwrx's Avatar
Originally Posted by june.rs
In my point of view, messing around with the ecu. could really harm my car. Tunning takes alot of time and you really have to know what the hell your doing. im not an F1 driver and my car is not a race car. All i wanted from my car is that rumble feeling and the sound of the bov. Thanks alot though guys. You really help.
Quite the contrary. Having TBE with no engine managment is going to damage your car! The whole point of EM is getting your ECU up to speed with the installation of after market parts to maximize the performance of those parts you have put on. Your car's ECU is setup from the factory to run a certain way in it's stock form, manipulating your ECU with CEL fixes so you can run a catless down pipe, let alone a bigger turbo and what not will have to require ENGINE MANAGEMENT! Without cats on your car we all know it is going to run rich to compensate for the extra fuel being dumped into the cylinders and that's not a good thing. If you ever want to modify your car with more power mods you will have to get EM and there is no way around that. Engine management is a posistive thing that helps your car run more effiecently(you will get better gas mileage too!), not damage it. It assists the ECU in adapting to different conditions where normally the ECU would be otherwise ineffective. I hope that clarifies some things.
Old Apr 6, 2007 | 03:54 PM
slowfoot's Avatar
How did the trans problem come out?
spencer721
Apr 22, 2010 12:18 PM
gdbimpreza
Mar 3, 2005 12:12 PM
gdbimpreza
Jan 20, 2005 05:25 PM
RedeemedSoul
Nov 25, 2004 11:40 AM
fastnoypi
Dec 4, 2002 02:59 PM
