Up Pipe Installation Needed
Old Mar 31, 2007 | 10:18 AM
june.rs's Avatar
Car Info: 07 pearl white wrx
I Need Help In Installing My New Up-pipe For My 07 Wrx
Old Mar 31, 2007 | 10:28 AM
STI RUSH's Avatar
Car Info: 13 FR-S/05 STI
www.scoobymods.com
Old Mar 31, 2007 | 10:55 AM
03_Impreza_Al's Avatar
Aren't they already catless?
Heres the link. I did it and was pretty easy try and get an extra hand to help though
http://www.scoobymods.com/forums/showthread.php?t=6649
Old Mar 31, 2007 | 01:48 PM
june.rs's Avatar
Do I Really Need An Up-pipe? I Mean It's Already Catless.
Old Mar 31, 2007 | 02:56 PM
Sell it and get a TBE =)
Old Mar 31, 2007 | 03:11 PM
june.rs's Avatar
Not To Sound Like A Noob But, What Is Tbe?
Old Mar 31, 2007 | 03:15 PM
june.rs's Avatar
Oh You Mean Turbo Back Ehuast. Well I Have The Blitz Nur Spec With Tanabe Down Pipe.
Old Apr 1, 2007 | 11:23 AM
1sicwrx's Avatar
Then yes, you have "turbo back exhaust". No, you don't need an uppipe due to your car coming from the factory with a catlees uppipe. Upgrading the uppipe is only necessary when you go with a bigger turbo than a VF series turbo(found on the STi, different and older models for the Impreza as well as Legacy's etc). Also PLEASE stop using capital letters to begin every word.
PS-Spend the money you used on the upipe for a rear sway bar or Engine Managment if you have the $$$$.
Old Apr 1, 2007 | 12:16 PM
kspek's Avatar
Car Info: non subarus
you already have a catless uppipe you don't need to change it.
Old Apr 2, 2007 | 10:35 AM
lburrrna's Avatar
i have a wrx 06, since im changing to fp18g next month then I should change my uppipe too?
Old Apr 2, 2007 | 06:35 PM
1sicwrx's Avatar
It's not totally necessary but some people recommend it with a bigger turbo. I did just to be sure.
Old Apr 2, 2007 | 06:44 PM
azn_ryder02's Avatar
Car Info: 2007 Satin White Pearl STi
uppipes
it is not COMPLETELY necessary to get an aftermarket uppipe BUT it would help your spool significantly because even though the stock uppipes are now catless the stock design itself is still pretty restrictive.
EDIT: I would HIGHLY suggest you use that money to get some sort of EM[COBB Accessport or HYDRA($$$)] b4 you buy the uppipe though
Old Apr 3, 2007 | 12:13 AM
june.rs's Avatar
my car is driven daily
In my point of view, messing around with the ecu. could really harm my car. Tunning takes alot of time and you really have to know what the hell your doing. im not an F1 driver and my car is not a race car. All i wanted from my car is that rumble feeling and the sound of the bov. Thanks alot though guys. You really help.
Old Apr 3, 2007 | 08:10 AM
WRBLUEballs's Avatar
Car Info: FUPA RIDER!
Sell it and to get the most bang for your buck you should buy a cobb AP. and it takes like a couple of minutes to install and doesn't have the car at all.
Old Apr 5, 2007 | 12:29 PM
wimprezax06's Avatar
Car Info: WRX --> RX-8--〉E93
06+ WRX already have a catless uppipe, so you dont need an aftermarket uppipe
