Help Needed ... Bov Installation!!
Old Nov 19, 2004 | 06:49 PM
playa7's Avatar
Car Info: JBP 04' WRX
ummm......ok lol
step 1: locate stock bov.
step 2: loosen/ remove 2 12mm bolts on stock bov flange.
step 3: remove vacuum hose and stock bov.
step 4: (depending on if your aftermarket bov is recircullating or not) cap return hose w/provided cap.
step 5: put on aftermarket bov.
step 6: screw in 2 12mm bolts.
step 6: put on vacuum hose on top of bov.
step 7: turn on car.
step 8: check for leaks.
step 9: rev engine to 5,500 rpm. hear the PhhhhsssssssstttTTTT????.....good
step 10: drive by old ladies and scare them with your new noise maker!
Old Nov 21, 2004 | 05:49 AM
New2MeSuby's Avatar
Car Info: 2007 Mazdaspeed 3, Black, 6spd
Agreed, unless you were silly and bought a non-model specific BOV. Do you have a flange that looks like the stock one?
Old Nov 25, 2004 | 11:01 AM
InfamousDX's Avatar
Car Info: '03 WRX Sedan
www.scoobymods.com is your friend.
Old Nov 25, 2004 | 11:40 AM
atreger's Avatar
Car Info: 02 WRX, BLACK
if u didn't get the matching flange to the IC, then u have to weld a piece of metal pipe between the IC and BOV
spencer721
Apr 22, 2010 12:18 PM
june.rs
16
Apr 6, 2007 03:54 PM
K6DimE
Mar 23, 2006 10:36 PM
cal_choi
Sep 15, 2003 10:06 PM
fastnoypi
Dec 4, 2002 02:59 PM
