Turbo upgrade (good for 300whp+ on '06 WRX)?
Old May 7, 2007 | 02:16 PM
undfndwrx's Avatar
Car Info: 06 REX
Please help!!! Im looking to buy a turbo....But, I do not want some big *** tranny breaking turbo. I want something streetable like the VF34... Is that a good turbo upgrade????? Please lmk!!!!
Thanks...:davis6:
Old May 7, 2007 | 10:34 PM
lburrrna's Avatar
Thanks...:davis6:
dude..you need to set your goal. wat did you want to do? wat power levels do you want??
Old May 8, 2007 | 12:22 AM
undfndwrx's Avatar
Car Info: 06 REX
At least 3xx to the wheels!!! Can the VF34 do that???? Plus I want reliability too...
Old May 8, 2007 | 01:13 AM
WhiTe_07_WRx's Avatar
Car Info: suby
search around man you will find great info on this subject
Old May 8, 2007 | 05:50 PM
lburrrna's Avatar
i dont think vf34 will do 300whp, unless it has good supporting mods, including front mount, injectors, fuel pumps, i would recommend to port your headers and add a crosspipe (much cheaper than buying a headers itself) plus its reliable compare to after market ( will crack overtime), AND you gotta a very good tune. just my 2 cent
Old May 9, 2007 | 11:03 AM
aboothman's Avatar
Car Info: Fast
dude, worry less about numbers, and more about how you want the car to drive. Do you want early boost with good torque early and decent pull through the powerband? Do you want big power after 4k RPMs all the way to redline? How do you drive your car?
If you want reliability, I would get a VF-22, 34, or 39. You will need a walbro, and an STI topmount would help. Ported manifolds do or do not help depending which tuner/shop you talk to, but they are by no means required. Same with a crosspipe.
A good tune is DEFINATELY required.
Old May 10, 2007 | 09:38 AM
pbtypes's Avatar
Car Info: 06 WRX TR
you should be able to hit 300 on the vf34. I did 334 on a 100 octane tuesday over at harman motive
Old May 10, 2007 | 07:30 PM
undfndwrx's Avatar
Car Info: 06 REX
What is your mods????:sprite-chimera-vile
Old May 11, 2007 | 10:34 PM
SuperHawk's Avatar
Car Info: 2006 WRB Wagon Ltd.
TD05-18G-8CM! This is the turbo that you want, of course other will say something else but this is my personal choice
SUper
Old May 11, 2007 | 10:35 PM
SuperHawk's Avatar
https://www.i-club.com/forums/engine-power-ej25t-sti-2006-wrx-90/06-wrx-18g-dyno-results-156920/
Old May 15, 2007 | 08:52 PM
GST Motorsports's Avatar
Former Sponsor
Car Info: WRX, EVO, MSP3
I would personally not bother with the VF34 on your setup, if your looking for something like that then perhaps look to get a used vf39 and STI TMIC from a STI owner upgrading and you'll be set for less than the price of the VF34.
A really good turbo on your car would be a TD06-18G which will have decent spool with conciderable top end gains, you will need a larger TMIC but the stock STI would work well.
Ported manifolds with Injen crosspipes will help for sure and will not crack (we run this setup on our race car and I am not telling you how much heat they see )
Mike
Old May 28, 2007 | 08:48 PM
pbtypes's Avatar
Car Info: 06 WRX TR
here is my dyno sheet
AWDnutjob
Jun 6, 2008 10:57 PM
nuhga
Dec 8, 2005 01:35 PM
xicema17x
Feb 1, 2005 10:06 PM
krzyxrevver12
Sep 27, 2003 03:35 PM
1WRX2NV
47
Sep 1, 2003 12:38 PM
