New turbo and PSI questions
Old May 1, 2007 | 11:36 PM
A170123W's Avatar
Car Info: 2007 Subaru Impreza WRX STi
I own a new 2007 STi and I was wondering is it true that the 07 STi uses a new turbo? If so, what kind of turbo is it and is it better than the 06 turbo? My last question is what is the PSI on a stock 07 STi?
Thank You
Old May 2, 2007 | 07:24 PM
MO REX's Avatar
Car Info: 02 PSM WRX
It has an IHI VF43. According to what I've read it's pretty much the same as the 39 but it has a larger internal wastegate so it will run a lower target boost.
Old May 12, 2007 | 01:54 PM
moved
Old May 13, 2007 | 09:58 AM
pj21086's Avatar
it will still have the same target boost but will be able to control it much better especially after you go catless (less chance of boost creep)
Old May 29, 2007 | 07:40 AM
BlaKKStaRR's Avatar
Car Info: WRX 2007
+1 i checked and the 06 and 07 have the exact same values for everything.
wantgoback
Nov 23, 2003 01:02 PM
O 16581 72452 5
Sep 18, 2003 09:37 PM
blackwagonrx
Jan 31, 2003 02:03 PM
schwarzenegger
Dec 3, 2002 01:33 AM
