Turbo removal
Old Mar 25, 2004 | 08:24 AM
dashiet's Avatar
yupp
http://www.scoobymods.com/forums/sho...=&threadid=329
:banana:
tell me how it goes, and how long it takes
Old Mar 25, 2004 | 06:47 PM
WRXYBOY's Avatar
Car Info: 08 TL Type-S
The hardest part is not taking the turbo off but putting it back on. What i did was bought oil clamps from my local autoparts shop and not use the butterfly ring on the oil return part of the turbo which is located on the bottom of the turbo. Also have a friend help you with that part or its gonna be a long time by yourself. Also when installing the turbo inlet to the turbo put a rag under the inlet hose and pull up it makes it easier to get on the turbo. Make sure on the oil feed bolt you mark where the holes are on top the bolt that way when you tighten it you can match the holes in the bolt with the same direction the oil flows.
Woodward
Feb 13, 2008 09:35 AM
DetailAddict
May 3, 2007 03:08 PM
ianalex
46
Jun 6, 2005 05:39 PM
_sti_05
Apr 19, 2005 09:18 PM
nic3krnnamja83
Sep 13, 2004 05:40 PM
