Removal of turbo
Old Apr 7, 2005 | 02:30 PM
_sti_05's Avatar
Car Info: 2005 STi
Removal of turbo
im planning on pnp my stock turbo, is there any special things i need to do besides just removing the bolts?
like unpluging the battery or something that wont mess up my car when i put the turbo back.
anyfeedback would be great
Old Apr 7, 2005 | 05:47 PM
PyroManiac's Avatar
From: Are you too one of the few still living the past? Well I can change that! With a simple wicket. Yes, my friend, a wicket. PM for details.
Car Info: No car right now....sob.
Always disconnect the negative battery terminal.
Old Apr 11, 2005 | 09:56 PM
UsafSti's Avatar
yea no reason to die... disconnet the battery
Old Apr 12, 2005 | 12:38 PM
Scoobyless's Avatar
Car Info: 04 Blue/Gold STi
yea, also make sure you clamp your coolant lines or plan on like a gallon of coolant draining out. Other than that, you should be all set, make sure you soak the bolts too, it helps...
Old Apr 13, 2005 | 06:53 AM
Egan's Avatar
And make sure you get the oil drain hooked up correctly when you put the turbo back on or you will end up with a lot of oil on the ground when you start the car.
Old Apr 19, 2005 | 09:18 PM
_sti_05's Avatar
Car Info: 2005 STi
so when i remove the oil and coolant lines will any of it come out or do i clamp them before i remove them from the turbo to prevent some spilling out?
any other things i should do.
Woodward
Feb 13, 2008 09:35 AM
DetailAddict
May 3, 2007 03:08 PM
ianalex
46
Jun 6, 2005 05:39 PM
nic3krnnamja83
Sep 13, 2004 05:40 PM
bcinlas4
Mar 28, 2004 07:19 PM
