Timed water sprayer
Old May 3, 2005 | 10:07 PM
4080wrx's Avatar
Timed water sprayer
I recently went to a local store that sold a pivot water sprayer controller that works off of your rpm's. Unfortunately the price for this little controller the size of a turbo timer was like 200 bucks. I was curious if anyone has thought of tapping off of the built in shift light on the sti so when the light indicator goes off it would send a signal to a relay amplifying a bit and then in turn trip the water sprayer button to spray at a predetermined rpm (i.e. whatever you set the shift light at)
any thoughts?????? anyone????
Old May 3, 2005 | 11:00 PM
isr96's Avatar
Car Info: 2007 suzuki GSX-R600
it sounds like a cool idea...
Old May 3, 2005 | 11:25 PM
gdogg's Avatar
Car Info: 1973 Huevo Ranchero
hey jess, did you buy it?? i hope not, cuz i have a summit racing catalog that has em for like 100 bucks before shipping...
i def. not no scientist but i think it would be a little more beneficial to have it sprayed prior to high rpms- unless you are referring for it to prep for the next shift...
i have a weird theory(which really has no merit) but i'd like to save the ampage(sp.? right term?) just for the engine and nothing else <--not very scientific- and i know the controller probably won't draw anything anyway...
Old May 4, 2005 | 08:51 AM
4080wrx's Avatar
gdogg,
i'm crazy but not that crazy to shell out that kinda money.
Old May 11, 2005 | 08:20 PM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
Use an adjustable pressure switch, that way, the I/C gets sprayed when needed under boost.
You'll need the switch, a relay, and a diode to prevent back feeding into the stock switch.
Old May 16, 2005 | 03:54 AM
Toiletbrush's Avatar
Car Info: '94 WRX, '97 Forester S/Tb, '95 WRX-RA
Just a question, because I dont really know...
I was under the assumption that automatic water spray came standard on the STi. I have a 98 and I can hit the I/C spray manually or push the auto button which gives the I/C a shot when you are peaking your boost. Can anybody clarify? Do the USDM STi's come with water spray stock?
Old May 16, 2005 | 03:56 PM
1WRXNFX's Avatar
Car Info: 2000 2.5 RS (really slow)
They do, but there manual, we have to push ours and they only spray for a small increment of time. I would however like to have something that would automatically spray the I/C when the temps reach a certain degree which would cause massive heatsoak and effect performace drasticaly
Old May 18, 2005 | 08:21 PM
iClub Silver Vendor
SPO sells a kit that that you splice into the existing harness that sprays under boost...it's about $150.
As I'm running water alcohol injection, I have an adjustable pressure switch that will be used to trigger the stock I/C sprayer as well.
Old May 19, 2005 | 08:53 PM
05STiChef's Avatar
mixture
is anbody running anything but just water in their IC spray? if so what are the benefits?
Old May 20, 2005 | 06:43 AM
iClub Silver Vendor
Distilled water will offer the best/most cooling effect on the I/C.
If you live in a cold area of the world, you might want to add a little alcohol to the tank to prevent freezing.
But performance will suffer.
Old May 23, 2005 | 10:02 PM
WrbImprezaSti's Avatar
Car Info: WRX
www.Kingofimports.com
they sell the JDM Auto I/C switch... replaces the USDM one. Cost's 40 bucks and is well worth it. (its like a on/off switch.
03impreza2.5rs
Nov 27, 2005 06:48 AM
Brfatal
17
Oct 27, 2003 05:02 PM
silver satin
Jul 5, 2003 02:24 PM
Mach5WRX
May 22, 2003 09:35 AM
B18c1
Jan 23, 2003 03:02 AM
Top
